Results 1 to 6 of 6
Thread: VAG-COm cable set up process
    I bought a cable and installed the software. The first thing it asks to do is test and save the communications port although it does not seem to recognise any available port.
    When I plug the cable into the USB port, the Windows "ding" indicates that it recongnises the cable, and the red LED illuminates on the VAG-COM.
    Is there any sequence that I should follow such as plug into car, then laptop, then turn on ignition etc?
    Cheers.
    2015 MY16 Brilliant Silver Octavia vRS Wagon TDI DSG with Tech Pack, 19" black pack, pano roof and auto tailgate
    I reckon that's in the online manual. Pretty sure you'll get a result by plugging it into the car with the ignition on. Gavin
    Cheers, I gave it a quick go today but had to head of shopping. It couldn't pick up a port (and I tried each option) so I thought maybe it is the sequence I plug everything in and turn it all on??
    Quote Originally Posted by MarksVRS View Post
    Check the ross tech site for details on loading the drivers.
    Jul 2010
    if i remember correctly - don't start the engine. "ACC/On" is where u need to b.
    so sequence:-
    1. plug vcds cable into car
    2. plug vcds cable into laptop
    3. turn key to 'acc/on'
    4. open vcds software
    when the red light on the vcds connector turns green, ur g2g.
    i believe that's wat did with mine last time i did some coding.
    MY17 Superb 162TSI, Business Grey, Tech+Comfort Pack, APR ECU+TCU Stg 1, SLA, Rieger Splitter + Side Skirts, Eibach Pro-Kit Springs, Hardrace Swaybar, TPMS
    Ah great, the green LED is a good indicator that I didn't check.
    I wasn't sure if I was pushing the plug in far enough as there was no "click" or resistance.
