The steering shouldn't have play in it. It's probably a worn "connector" at the bottom of the steering shaft. I think WFDTamar had a similar issue.
The Auto (it's a traditional auto box IIRC) is supposed to be sealed for life but in reality should be serviced every 60,000km, so it should have a couple of service stamps by now.
The engine should have had the timing belt done at least once depending on whether they chose time ( 4-6 years - opinions vary) or distance (105,000km) plus they should have done a few pulleys & maybe a water pump while they were in there.
Servicing is every 12m/15,000km but a lot of us do it at shorter intervals. The oil type is very important and it should be VW505.00 or 507.00 spec.
Fuel injector & fuel pump clean? I don't think so but others on this forum know more about diesels than me. Maybe post a thread in the diesel section directing them here?
What you probably have to budget for is an EGR clean and maybe a chemical clean of the turbo.
Alba European (Jmac on this forum) comes very highly regarded. There are a few others - have a look in the "recommended repairers" sub forum for other VW group specalists. Something Prestige in Cooparoo rings a bell.....
If it's a 2007 it better be as cheap as chips. I have a 2007 build Elegance spec 118tsi manual sedan with 150,000km. As a private sale it's worth $8k at the very most. A lot of the private sellers on car sales are dreaming.
Is this the car?
2007 Skoda Octavia Ambiente Direct-Shift Gearbox
If so why does the speedo say 105,000km but the ad 135,000?
The photos are poor - is the back seat leather?
As it's a base spec Ambiente & less desirable sedan and the rego is due in Feb & it's about to become an 8 year old car, I'd offer a lot less than he's asking.
If you aren't worried about the body or know a panel beater / paintless dent place then this one is worth a look.
2008 Skoda Octavia Elegance
