![Quote](https://www.vwwatercooled.com.au/forums/images/misc/quote_icon.png)
Originally Posted by
Skooter
My unit wouldn't even recognise Bright, Victoria - a rather large town in the Ovens Valley! And I've upgraded the maps to the 'latest' via the link provided in this forum. Bizarre.
Ah yes it does, RTFM....when you enter Bright it will display Bright (SA), at the end of the line is a highlighted button with 14, if you press this it will list the 14 entries that start with Bright, Bright Vic is second on the list. There is also a function key to the right, which upon pressing will, and I will quote the manual for the columbus, " ..a list will open with all the destinations containing the relevant parameters selectable from the navigation memory (eg country, city)
Hope this helps.
08 Octavia vRS Manual|DNA Stage 2 Tune|Golf R Intercooler|APR DP|Carbino Intake|Uprated DV|Porsche Calipers (NQSBBK)|Superpro Alloy front control arms and bushes|42DD Stealth Catch Can and PCV|42DD Shift Bushes|Whiteline adjustable rear sway|Superpro torque arm bush| Front and rear lower strut braces|Whitline steering rack bush|
