Page 16 of 24 FirstFirst ... 61415161718 ... LastLast
Results 151 to 160 of 233
Thread: Tyre Options
  1. #151
    Erskineville, NSW
    plug some figures into the link. 7.5 ET51 has less brake clearance than 8 ET42. Orange profile is original, green is modded.
    eg: when I had 17x8 ET35 they poked outwards too much. In order to bring them under the guards I was going to machine 10mm off the inner wheel face where it mates with the hub. Resulting ET would have been 45. I agree, it makes no sense.
    Edit: If you old rims =18x7.5 ET52 and the new rims = 18x8 ET42 and the design / proportions of the rim were exactly the same then the ET42 rims would have about 3mm extra clearance between the spokes & the brake caliper.
  2. #152
    Dec 2012
    Sutherland Shire, Sydney
    Stock brake caliper to spoke clearance should not be an issue at all
    (the stock caliper is all on the other side of the disk rotor)
    It did have problems with my BBK calipers, the Neptunes hit them
    I had another set of wheels that needed a 3mm spacer - sold them
    The Audi RS3 wheels have spokes with good clearance - no spacer needed
  3. #153
    Oct 2009
    Mitchelton, Qld
    Well I just ordered my Alzor 349 18*8 ET45. They will be on a slow boat from the USA so I'm not expecting them to land in Brisbane for another 2 mths+.
    Now the wait begins.
    Still deciding on whether to go with the stock tyre sizes (225/40) or go that little bit wider (235/40) to avoid the rim poke past the tyre wall look (which I don't like visually or protective for the rims).
  4. #154
    Oct 2009
    Mitchelton, Qld
    Quote Originally Posted by Martin View Post
    These are what I've used
    Michelin PS3
    Lovely all round tire, lasts well, great grip in both dry and wet, not very noisy
    When going hard the initial turn in response a little soft
    Goodyear F1A2
    A little more dry grip than the PS3, maybe a little less wet grip than PS3
    Last very well but more noisy than PS3
    When going hard they are simply awesome, brake hard, turn response is excellent, makes your day
    Given the price and performance of these tyres, it's really hard to consider others
    Conti CS3
    Very hard wearing, pretty noisy (gets bad when below 50% tread), they often slam through pot holes
    Need to pump them up pretty hard to get the turn in response I wanted
    Very good level of dry grip - wet was ok also
    The only point where they really shine is the km you get out of them (with good level of grip)
    Generally I would not buy these given the price
    Bridgestone Potenza 040 & 050
    High grip level in the dry, on wet days needed to get them warm first
    Prone to axle tramp on hard launches
    Turn in is good - braking is great
    Price is simply awful
    Maxis M35
    I had these on the wife's Mazda3
    Surprising tyre - does everything ok - lasting well - price was ok
    Hard launch was better than the 040 (no axle tramp)
    Continental Contact MC5
    We got these in a "pay for 3 get 4" deal - they are on the Mazda3
    Surprising tyre - does everything ok - lasting well - price was good
    Well after fitting Goodyear F1A2 to my Occy RS on the weekend and testing them out today, I have to say my axle tramping is all but eliminated and I now have my full first gear back in action thank goodness. It's like night and day between the Goodyears and Conti's when it comes to axle tramping!!!!
    Very happy indeed.
  5. #155
    Dec 2012
    Good to hear you're happy with them
    I would have to revise my opinion of the Maxis M35
    My wife is a very gentle driver, hence they are lasting ok for her
    But I'm on good terms with the local tyre shop,
    they don't like selling the M35 due to poor km/life and associated customer dissatisfaction
    They find is easiest to sell them during the pay for three get one free specials
  6. #156
    Oct 2009
    Mitchelton, Qld
    I still can't believe the night and day difference. After the mods such as LCAs and dogbone inserts to try and eliminate the axle tramping, the biggest bang for buck in eliminating the axle tramping has by far been the new tyres.
    Rolling resistance seems a little higher on the Goodyears but?
  7. #157
    Erskineville, NSW
    Quote Originally Posted by donweather View Post
    You got new rims as well. Is the new rim/tyre combo lighter than the old one?
  8. #158
    Oct 2009
    Mitchelton, Qld
    Yes, but not by a significant amount. Maybe 1-2kgs per corner tops. So 10% lighter say.
  9. #159
    Erskineville, NSW
    1kg unsprung is worth 2-4kg sprung (depends who you're talking to), so there would be a benefit but good tyres should always be the first mod IMO.
  10. #160
    Oct 2010
    That's quite a saving in unsprung weight as brad said. Would actually make a decent difference even if you had the same tyres, although I suspect tyres made the biggest difference.
    2014 Skoda Ambition Plus 103TSI candy white wagon, 6sp Manual, Tech pack, Panoramic Sunroof, 18's, Colour Maxidot, Comfort BT
    Ordered 07 May 14 (Wk 15), Built Wk 37, Loaded 27/9 (wk 39), Docked 12/11 (wk 46), DELIVERED! 12/12 (end of wk 50 - 7 months + 1 week).
