Page 15 of 24 FirstFirst ... 51314151617 ... LastLast
Results 141 to 150 of 233
Thread: Tyre Options
  1. #141
    Oct 2009
    Mitchelton, Qld
    Brad is yours a mk 2 or 3 and RS or non RS?
  2. #142
    Erskineville, NSW
    Quote Originally Posted by donweather View Post
    2007 build MK2 Elegance hatch. M6 1.8tsi, 138,000km. Bluefin tune since 50,000km; Eibach springs, koni yellows, vRS/GTI 312mm front brakes, other minor stuff.
    I've had 4 sets of wheels/tyres on it.
    16x6.5 ET50 + 205/55r16
    17x8.0 ET35 + 235/45r17
    16x7.5 ET50 + 225/55r16
    17x7.5 ET45 + 225/50r17
  3. #143
    Apr 2012
    Perth
    So have had the PS3's on for a few weeks now.
    They're quiet - and so far stopping and handling in the wet and dry has been good (haven't really pushed them too hard, but have had to make one or two quick stops, and they did well).
    However, accelerating relatively hard from a standing stop, particularly when turning, I'm getting a bit of wheel spin.. bit disappointed, I did get it on the stock tyres, but seems worse now.
  4. #144
    Oct 2009
    Mitchelton, Qld
    Deeps, wheel spin or axle tramp? What's your occy model also?
  5. #145
    Apr 2012
    Perth
    I think it's more axle tramp. Got the 118tsi 2012
    I remember about a month back i really floored it from a standing stop and got an almighty shudder. I thought it was the clutch, as it needs to be replaced, but now I'm thinking maybe that was axle tramp too.
  6. #146
    Oct 2009
    Mitchelton, Qld
    Further to my post above regarding the Cades, will the ET42 have any issues with clashing with the RS brake calipers?
  7. #147
    Erskineville, NSW
    No. You can run 16" ET52 on the 312mm vRS brakes with about 6mm clearance.
    It would have to be a really poorly / weirdly made 17" or 18" to interfere with 312mm vRS brakes.
  8. #148
    Oct 2009
    Mitchelton, Qld
    Ok thanks Brad. With respect to your ET52 response isn't the clash with the brakes worse on a lower ET, say ET42?
  9. #149
    Erskineville, NSW
    All other dimensions being equal (ie: 17x7 rim) the ET50 offset has 15mm less outward poke (or is 15mm closer to the strut) than an ET35. If you change the width of the wheel then the offset distance changes even if the ET remains constant, so you have to consider both width & ET when working out where the wheel sits within the guards.
    Possibly this calculator will help visualise what I mean. It shows a strut & the outline of before & after different wheels, tyres, diameters, offsets, etc
  10. #150
    Oct 2009
    Mitchelton, Qld
    Thanks Brad. But its not the clearance to the strut that's the problem. it's the clearance to the brake calipers which are closest to the inside surface of the rim and so with a lower ET you have less room between the intrados of the rim/spokes and the brake calipers.
