![Quote](https://www.vwwatercooled.com.au/forums/images/misc/quote_icon.png)
Originally Posted by
donweather
Are front camber/castor adjustable with the supaloy LCAs with adjustable lower ball joints?
The supaloy comes in two packages, standard and extra which has an adjustable lower ball joint.
Chasing castor will reduce the amount of static camber you can have - which is ok
(Caster creates more negative camber when you turn the steering wheel)
