scratch the rear axle.......
Maybe one of these will fit the bill
NEW 2 TON 4500LB AUTO CAR BODY ROTISSERIE TWIRLER RESTORATION LIFT JACK | eBay
MY17 Superb 162TSI, Business Grey, Tech+Comfort Pack, APR ECU+TCU Stg 1, SLA, Rieger Splitter + Side Skirts, Eibach Pro-Kit Springs, Hardrace Swaybar, TPMS
Sure.
You'd never lift in the centre of an arm - but you probably couldn't because there's nothing for the jack pad to grab onto.
Generally you can lift on a pivot point or knuckle.
Each time you lift you should assess what may happen & the appropriateness of what you are doing.
Nothing like that on my car. Maybe they've reduced the gauge of the steel?
I'd still have no issue lifting straight underneath the spring except it's a bit slippery. The pivot point up the front isn't too bad but I know from experience that the jack pad isn't totally secure in that spot.
