Results 1 to 10 of 10
Thread: Tried another dog bone today
    Dec 2012
    Sutherland Shire, Sydney
    Spent a few hours messing around under the car to install this one
    Unfortunately the cabin noise in first and reverse is too harsh
    I reckon they got the stock one perfect from a comfort point of view
    Now I have to find time to remove it!
    Erskineville, NSW
    What a coincidence!
    I fitted the remnants of your old one to my car this afternoon. Had to make a retaining tab for it as my car only had a 25mm washer - not a 75mm (or whatever it is). No idea if it made any difference - didn't drive the car (or start it).
    I doubt the whole bush would fit - it looks different-ish.
    Koni struts go in tomorrow
    Damn you got the hard one man. As discussed, i got the 75a version and even that one is borderline annoying me and thats in a manual. I can imagine the vibrating is worse in a DSG.
    Dec 2012
    Yes, I wonder if the multiplate clutch has anything to do with it
    Having tried a few options, you just can't can't go any harder with the DSG Octavia
    Like you I managed to remove the stock one without damaging it
    Bonus - at least you can re-install the stock one then. I think the inserts that work with the stock rubber mount are a good compromise. I may end up removing my HPA one but im going to leave it in for a few more weeks yet and make my mind up.
    Erskineville, NSW
    Fill the void in the OEM with silicone?
    Bowral, NSW
    Where do you guys buy these, and how much?
    2012 Octavia vRS TDI. Darkside big turbo, 3bar tune, other stuff. 200kW/650Nm.
    1990 Mk1 Cabrio. 1.9 IDI w/ 18PSI.
    1985 Mazda T3500 adventuremobile. 1973 Superbug. 1972 Volvo 144 in poo-brown.
    Not including hers...
    Erskineville, NSW
    search engine mount insert. There are lots of brands & they do have some slight differences in physical shape & the density of the material.
    The shape changed in 2009.
    They start about $40 on ebay but check out Black Forest Industries, APR, etc. There's probably a thread in the Gold section about the best ones.
    They are all around the same price - a few dollars here and there different.
    You can get Whiteline and Powerflex ones on ebay, and BFI (Black Forest Industries) through DubAddiction.
    Dec 2012
    Like so:
    POWERFLEX ENGINE MOUNT DOG BONE BUSH KIT VW GOLF MK5 | eBay
    Today I removed my one, so much nicer, no more messing around with dog bone inserts for me!
