Results 1 to 10 of 13
Thread: Transmission (dogbone or pendulum) mount upgrade
    Dec 2012
    Sutherland Shire, Sydney
    Unhappy Transmission (dogbone or pendulum) mount upgrade
    The stock transmission (dogbone or pendulum) mount has holes to allow some vibration
    There are numerous after market inserts to make it firmer:
    APR
    Powerflex
    BSH
    ECS
    I've installed one - arggg - it's awful
    Anytime the engine is below 1500rpm the cabin resonance is like having your ears boxed
    Makes rush hour stop traffic harder to tolerate
    Even when driving along at a nice cruising speed, you press the throttle a little harder, that short wait for the DSG to change down where the engine labours a little causes unpleasant resonance
    It's going to have to come out I think...
    Apr 2010
    Depends on what duro rating you get.
    I have a Whiteline one from eBay which I think is rated only around 75, for the first 2 weeks I had vibrations through the brake pedal when stopped, and when reversing, but now it's not noticeable (only sometimes when reversing uphill).
    The 90 duro one is much more race-car-ish and has worse NVH.
    Dec 2012
    That's interesting, I thought my one was soft (70) but am not sure
    I'll see if it settles in/down - thanks
    Jul 2010
    u need atleast 90 duro for dsg equipped cars.
    80 for manual transmissions.
    which one did u install by the way?
    MY17 Superb 162TSI, Business Grey, Tech+Comfort Pack, APR ECU+TCU Stg 1, SLA, Rieger Splitter + Side Skirts, Eibach Pro-Kit Springs, Hardrace Swaybar, TPMS
    Dec 2012
    I have the powerflex - it was the cheapest
    Jan 2012
    I have a whiteline one. barely know its there except the vibration in reverse at low RPM
    Erskineville, NSW
    Martin
    Can I give it a try in my car & see how it goes?
    Dec 2012
    You certainly can Brad - I'll see if I can have it removed on Sat morning
    I must admit, the vibrations have calmed down a fair bit
    Not sure if it's now seated nicely or if the grease has now done it's job
    But vibrations and noise from idle, starting in 1st and reverse are still too intrusive for my liking
    Erskineville, NSW
    Do you wish to come over sometime & I'll remove it rather than paying to get it done?
    Dec 2012
    Great idea - I drive past Blakehurst weekdays between 5pm and 6pm
    But I imagine the weekend is better for you
    Let me know what suits you
    Cheers...
