The default on a fresh engine start is Traction Control = ON. If th eengine is going & you press the button then the skidding car light inside the RH dial (the tacho?) will permanently illuminate (possibly with the words "OFF" illuminated underneath but that may be the wife's Commodore???).
Flashing quickly when hammering through roundabouts means that TCA is enabled & doing the job.
