Towbar vs. Towbar
So!!
I have a conundrum, and would like to put forwards a vote.
I'm stuck between two towbars... as the title would suggest.
Bar #1:
Ironbull bar
Things that matter to me:
Extremely hard to find accessories
1,500kg weight rating
100kg ball weight
Price
Pics:
(IMG sauce: http://www.vwwatercooled.org.au/foru...tml#post854364)
Bar #2:
Hayman Reece bar
40mm detachable/interchangeable tongue
Can easily attach accessories (Bike rack; Thule cargo box; Caravan weigh distribution - "stabilizer" - bars)
1,300kg weight rating
75kg ball weight
Will probably be installed by the dealership.
Pics:
If I go for the Hayman Reece, I can change the tow cup on my camper trailer to the TREG hitch that I've been planning on doing for awhile now.
I can just take out the tow hitch unit and swap it with a 50mm ball, any time I want to tow something thats not my camper trailer.
If I go for the Ironbull, it will be stronger... But I won't be able to use the TREG on the camper trailer; nor use the Thule cargo box or bike rack I eventually plan to get.
I've had a look at the Euro-bar compatible versions, and I don't really like them all that much...
Things to note:
I eventually plan to get a small caravan (10-12ft; 800-1,000kg) - so the ability to use stabiliser bars would help.
I eventually plan to get a heavy-duty 4WD for bush camping, so will end up with TREG hitch for camper trailer ANYWAY.
The Octavia vRS is spec'd at 1,300kg max trailer weight, anyway, so the added capacity of the Ironbull bar would be more for peace of mind, rather than actual use.
I like the look of the Hayman Reece, and I dislike the look of the Ironbull... But that doesn't really mean much, as far as usability goes.
TREG hitch:
I'm really stuck.
What do you lot think I should go for?
2012 Octavia vRS TDI. Darkside big turbo, 3bar tune, other stuff. 200kW/650Nm.
1990 Mk1 Cabrio. 1.9 IDI w/ 18PSI.
1985 Mazda T3500 adventuremobile. 1973 Superbug. 1972 Volvo 144 in poo-brown.
Not including hers...
