Page 6 of 6 FirstFirst ... 456
Results 51 to 60 of 60
Thread: Towbar revisited
Nyyyko Towbar revisited 10-02-2016, 02:46 PM
zei20t Install yourself? How hard... 11-02-2016, 11:05 AM
Nyyyko Ive done one my fair share of... 12-02-2016, 06:57 AM
daljames You will have to VCDS the car... 11-02-2016, 05:47 PM
Nyyyko I thought so re the coding.... 12-02-2016, 07:00 AM
Nyyyko What needs to be removed to... 01-03-2016, 02:32 PM
Nyyyko I've finally got the tow bar... 01-03-2016, 02:34 PM
Nyyyko So I'm still hoping that... 12-02-2016, 06:59 AM
Guest001 Westfalia | Melbourne Towbars... 12-02-2016, 08:36 AM
zei20t AFAIK its the red plug to the... 02-03-2016, 08:55 AM
Nyyyko I fit the bar this past... 17-03-2016, 10:07 PM
zei20t any chance you took some... 18-03-2016, 01:57 PM
woofy That seems odd, I wasn't... 18-03-2016, 09:02 AM
Nyyyko No photos. Thought about it.... 24-03-2016, 08:21 PM
GTR27 Can you import the factory... 25-03-2016, 04:29 PM
Smart1 You won't have the mandatory... 25-03-2016, 05:51 PM
Smart1 Also, the dealer fitted one... 25-03-2016, 05:52 PM
GTR27 It's **** that we can... 26-03-2016, 09:16 AM
Nyyyko The westfalia bar is approved... 29-03-2016, 08:16 AM
GTR27 Is the westfalia bar fully... 29-03-2016, 10:16 PM
LunchboxVRS Most of the mk3 Octavias Iv... 10-04-2016, 08:35 PM
Nyyyko Paid 740ish for removable... 11-04-2016, 07:15 AM
Guest001 Just so you are aware The... 29-03-2016, 10:34 PM
Smart1 Is that the manufacturer... 29-03-2016, 10:35 AM
zei20t how did you go with the... 31-03-2016, 02:19 PM
zei20t so ive ordered a westfalia... 06-04-2016, 09:08 AM
Nyyyko Installed the wiring last... 10-04-2016, 07:40 PM
GTR27 When you guys say already has... 12-04-2016, 08:15 PM
LunchboxVRS RS, but Iv seen some non RS... 12-04-2016, 08:22 PM
Smart1 Both mine and my wife's have... 12-04-2016, 08:30 PM
zei20t i received the westfalia... 13-04-2016, 02:20 PM
Nyyyko Neck won't fit in the styro... 20-04-2016, 11:32 AM
zei20t Martin cc'd her in on our... 21-04-2016, 11:45 AM
zei20t i thought about that, but i... 21-04-2016, 11:47 AM
Nyyyko Correct smart1, the factory... 12-04-2016, 08:59 PM
Smart1 For those who haven't seen... 12-04-2016, 09:23 PM
woofy I have a feeling all... 13-04-2016, 12:48 AM
zei20t installed the wiring and tow... 13-04-2016, 08:55 PM
LunchboxVRS Did you have to run wiring to... 13-04-2016, 09:34 PM
zei20t for my car with tow prep, the... 15-04-2016, 12:03 PM
zei20t towbar install was fairly... 18-04-2016, 10:11 AM
arriba Hi, Please put some photos of... 21-04-2016, 02:50 PM
Nyyyko You should not have needed to... 20-04-2016, 11:35 AM
Nyyyko Of note is that the newer... 20-04-2016, 11:37 AM
zei20t yeah photos dont want to... 25-04-2016, 08:15 PM
zei20t OK, photos of the work! ... 27-04-2016, 02:19 PM
LunchboxVRS So just tried to fit the... 07-05-2016, 01:40 PM
zei20t hmmm mk3 is a new beast it... 08-05-2016, 07:36 PM
LunchboxVRS I thought that too as I had... 08-05-2016, 08:28 PM
zei20t hmm perhaps they are... 09-05-2016, 08:47 AM
LunchboxVRS Turns out that Skoda changed... 09-05-2016, 05:44 PM
zei20t where did you buy it from? ... 10-05-2016, 08:36 AM
Nyyyko It's finally happened. Took... 15-06-2016, 07:37 PM
zei20t good to hear :) ill be... 17-06-2016, 11:56 AM
zei20t so, towed around 1300kg of... 27-06-2016, 09:21 AM
LunchboxVRS Does it not have a key to... 27-06-2016, 05:12 PM
zei20t yes it does. and it was... 28-06-2016, 11:26 AM
DETROITCANDY Superb 162TSI braked tow... 28-06-2016, 12:44 PM
LunchboxVRS It will be what the chassis... 28-06-2016, 04:14 PM
Guest001 The rules say you can tow the... 28-06-2016, 05:47 PM
    May 2012
    Quote Originally Posted by zei20t View Post
    hmm perhaps they are supplying the wrong part with the kit?
    i need to take mine off, or just leave it where i left it and deal with it. if it doesnt fall off and doesnt foul anything, i really dont mind where it is
    Turns out that Skoda changed there towbars for mid 2014 onwards compared to the ones they had for release in 2013. The wiring has changed 3 times. Once with each Towbar and agin in 2015. Seems westfalia have not cought up in Aus as the only offer the 2013 version.
    Have comm6acted westfalia and waiting a response. Think I'll just get a refund and buy the genuine Skoda one and fit it myself....again.
    MY16 Candy white Octavia VRS Wagon, sunroof, 19" black pack, tech pack, comfort pack, auto tail gate
    MY12.5 Polo 6R GTI
    Jan 2012
    Quote Originally Posted by lunchboxGTI View Post
    if its the place i got mine, they are very reasonable people and will do what they can to help you out
    Oct 2015
    Castlemaine vic
    It's finally happened. Took the caravan for its maiden voyage over the long weekend. Skoda went well, 3 hours each way. Good pull, nice handling, braking tops. Probably close to 1300kg with the stuff loaded. May weigh next time. Averaged 14.9 l/100 out and 13.1 on the return. Power to the fridge whilst towing, gas while camping. solar setup for lights and charging stuff. So good. Thanks to all on this thread
    Attached Thumbnails Attached Thumbnails Towbar revisited-image-jpg
    Jan 2012
    good to hear
    ill be towing 1300kg around this weekend. not worried too much about the economy, as long as it goes ok and handles well.
    how much weight did you have on the ball? got some gas bottles and water on the A-frame there
    Jan 2012
    so, towed around 1300kg of trailer and racecar last weekend. traveled fine!
    found a minor design flaw with the gooseneck attachment/detachment wheel.
    when you want to detach the gooseneck, you turn the wheel away from you, the top goes towards the front of the car. well, when i ran over a kangaroo on the highway, the carcass of the roo kindly detached the gooseneck on my behalf, while i was traveling at around 70-80km/h.
    thankfully, the trailer hitch got stuck under the boot floor and i brought the whole thing to a stop safely. managed to drive it all home - once the goosneck was kind of forced back onto the car.
    anyway, you'd think the europeans would have thought of that! im getting insurance to install a HR bar, might look ugly, but roadkill wont actually attempt to kill me lol
    May 2012
    Does it not have a key to lock it. My westfalia has to be pulled away from the neck before it will turn and won't turn or pull out without the key inserted and turned
    MY12.5 Polo 6R GTI
    Jan 2012
    yes it does. and it was locked and the key removed.
    but put enough force on anything in the right way and it will break. it was a big roo
    ill ask for the gooseneck back once the car is repaired, and ill have a look at whats broken. might take to it with an angle grinder
    Sep 2012
    Superb 162TSI braked tow capacity = 2000kg.
    Octavia 162TSI RS braked tow capacity = 1600kg.
    Both have same driveline and MQB platform with independent rear ends.
    Can anyone tell me what the mechanical/structural difference is that makes the heavier superb a more capable tow car. I have no experience with towing and haven't really thought about it much until recently.
    I'd love to be able to tow my currently street registered track car and a trailer with an Octavia if/when I decide to de-register my track car. Car is approx. 1400kg before trailer.
    May 2012
    Quote Originally Posted by DETROITCANDY View Post
    It will be what the chassis and suspension can handle. The towbars are rated at more then the car will take. I think mine says 2000kg
    MY12.5 Polo 6R GTI
    Pacific Paradise QLD
    The rules say you can tow the LESSER of the cars capacity or the Towbars capacity.
    So car limit 1500kg Towbar 2000kg legal for 1500kg.
    Car limit 1500kg Towbar 1200kg legal for 1200kg
    The weighed tow weight is the ATM of the trailer which is the plated legal loaded weight limit of the trailer on its wheels and jockey wheel
