Page 5 of 6 FirstFirst ... 3456 LastLast
Results 41 to 50 of 60
Thread: Towbar revisited
Nyyyko Towbar revisited 10-02-2016, 02:46 PM
zei20t Install yourself? How hard... 11-02-2016, 11:05 AM
Nyyyko Ive done one my fair share of... 12-02-2016, 06:57 AM
daljames You will have to VCDS the car... 11-02-2016, 05:47 PM
Nyyyko I thought so re the coding.... 12-02-2016, 07:00 AM
Nyyyko What needs to be removed to... 01-03-2016, 02:32 PM
Nyyyko I've finally got the tow bar... 01-03-2016, 02:34 PM
Nyyyko So I'm still hoping that... 12-02-2016, 06:59 AM
Guest001 Westfalia | Melbourne Towbars... 12-02-2016, 08:36 AM
zei20t AFAIK its the red plug to the... 02-03-2016, 08:55 AM
Nyyyko I fit the bar this past... 17-03-2016, 10:07 PM
zei20t any chance you took some... 18-03-2016, 01:57 PM
woofy That seems odd, I wasn't... 18-03-2016, 09:02 AM
Nyyyko No photos. Thought about it.... 24-03-2016, 08:21 PM
GTR27 Can you import the factory... 25-03-2016, 04:29 PM
Smart1 You won't have the mandatory... 25-03-2016, 05:51 PM
Smart1 Also, the dealer fitted one... 25-03-2016, 05:52 PM
GTR27 It's **** that we can... 26-03-2016, 09:16 AM
Nyyyko The westfalia bar is approved... 29-03-2016, 08:16 AM
GTR27 Is the westfalia bar fully... 29-03-2016, 10:16 PM
LunchboxVRS Most of the mk3 Octavias Iv... 10-04-2016, 08:35 PM
Nyyyko Paid 740ish for removable... 11-04-2016, 07:15 AM
Guest001 Just so you are aware The... 29-03-2016, 10:34 PM
Smart1 Is that the manufacturer... 29-03-2016, 10:35 AM
zei20t how did you go with the... 31-03-2016, 02:19 PM
zei20t so ive ordered a westfalia... 06-04-2016, 09:08 AM
Nyyyko Installed the wiring last... 10-04-2016, 07:40 PM
GTR27 When you guys say already has... 12-04-2016, 08:15 PM
LunchboxVRS RS, but Iv seen some non RS... 12-04-2016, 08:22 PM
Smart1 Both mine and my wife's have... 12-04-2016, 08:30 PM
zei20t i received the westfalia... 13-04-2016, 02:20 PM
Nyyyko Neck won't fit in the styro... 20-04-2016, 11:32 AM
zei20t Martin cc'd her in on our... 21-04-2016, 11:45 AM
zei20t i thought about that, but i... 21-04-2016, 11:47 AM
Nyyyko Correct smart1, the factory... 12-04-2016, 08:59 PM
Smart1 For those who haven't seen... 12-04-2016, 09:23 PM
woofy I have a feeling all... 13-04-2016, 12:48 AM
zei20t installed the wiring and tow... 13-04-2016, 08:55 PM
LunchboxVRS Did you have to run wiring to... 13-04-2016, 09:34 PM
zei20t for my car with tow prep, the... 15-04-2016, 12:03 PM
zei20t towbar install was fairly... 18-04-2016, 10:11 AM
arriba Hi, Please put some photos of... 21-04-2016, 02:50 PM
Nyyyko You should not have needed to... 20-04-2016, 11:35 AM
Nyyyko Of note is that the newer... 20-04-2016, 11:37 AM
zei20t yeah photos dont want to... 25-04-2016, 08:15 PM
zei20t OK, photos of the work! ... 27-04-2016, 02:19 PM
LunchboxVRS So just tried to fit the... 07-05-2016, 01:40 PM
zei20t hmmm mk3 is a new beast it... 08-05-2016, 07:36 PM
LunchboxVRS I thought that too as I had... 08-05-2016, 08:28 PM
zei20t hmm perhaps they are... 09-05-2016, 08:47 AM
LunchboxVRS Turns out that Skoda changed... 09-05-2016, 05:44 PM
zei20t where did you buy it from? ... 10-05-2016, 08:36 AM
Nyyyko It's finally happened. Took... 15-06-2016, 07:37 PM
zei20t good to hear :) ill be... 17-06-2016, 11:56 AM
zei20t so, towed around 1300kg of... 27-06-2016, 09:21 AM
LunchboxVRS Does it not have a key to... 27-06-2016, 05:12 PM
zei20t yes it does. and it was... 28-06-2016, 11:26 AM
DETROITCANDY Superb 162TSI braked tow... 28-06-2016, 12:44 PM
LunchboxVRS It will be what the chassis... 28-06-2016, 04:14 PM
Guest001 The rules say you can tow the... 28-06-2016, 05:47 PM
    Jan 2012
    towbar install was fairly straight forward. removing the crash bar was fun. didnt see the bolts until some of the panel sealer was removed.
    had to trim about 40mm extra from the bumper to get it to fit. but as i already had tow prep, it wasnt a huge job.
    getting the bumper off and on was probably the most difficult part.
    will post pics later
    Jun 2015
    Quote Originally Posted by zei20t View Post
    Hi, Please put some photos of the install up when you get a chance.
    Thanks!
    Oct 2015
    Castlemaine vic
    You should not have needed to remove any more bumper for the bar. The key is to install the bar as far forward as possible within the long bolt on slot. Went to put bumper back on and found this out. Slid it in as far as I could and presto. I did need to cut off one of the rear lower bumper screw mounts to make way for the plug to swing up and out of the way. Quick and easy
    Oct 2015
    Castlemaine vic
    installed the wiring and tow module tonight. fairly easy to be honest. VERY glad my car had tow prep.
    coded fine and passed diagnostics with the westfalia branded module
    ill post photos after the towbar is installed on saturday.
    Of note is that the newer CANBUS modules accept LED lights without needing to install load resistors... No pesky bulb failure warning!
    Jan 2012
    yeah photos dont want to upload. ill have to put them on my one drive and link to them
    Jan 2012
    Firstly, after taking off the rear bumper. The crash bar is bolted on to the end of the chassis rails. its semi stuck on with body sealer. Have to be VERY careful you dont tear it off the car. Need to cut it where required to remove the crash bar:
    Towbar revisited-wp_20160416_12_24_15_pro_li-jpg
    Crash bar removed, I used an enamel paint on the exposed metal area, just to make sure nothing would easily get rusty:
    Towbar revisited-wp_20160416_12_30_22_pro_li-jpg
    Towbar in installed position. It basically replaces the crash bar location. But bolts on down the chassis rails instead of on the end of them:
    Towbar revisited-wp_20160416_14_29_34_pro_li-jpg
    Close up of some more painting exposed areas. I did several coats just for fun:
    Towbar revisited-wp_20160416_14_29_40_pro_li-jpg
    Where the gooseneck fits into place:
    Towbar revisited-wp_20160416_14_29_51_pro_li-jpg
    Completed install and bumper - slightly trimmed - back into place:
    Towbar revisited-wp_20160416_16_19_39_pro_li-jpg
    Took probably 2.5 hours with some assistance to remove and replace the bumper. it was probably the most painful part of the installation.
    May 2012
    So just tried to fit the westfalia Towbar to my mk3 vrs. It's a my 16 built 12/15. Seems the changed the tow prep wiring. It's not the red plug. Same shape but black and less wires. Also the tow bar is to far in and the bar Dosnt fit on to the lower section. Westfalia said there is new wiring kit and a new attachment for the hitch to go into but Dosnt solve the issue.
    MY16 Candy white Octavia VRS Wagon, sunroof, 19" black pack, tech pack, comfort pack, auto tail gate
    MY12.5 Polo 6R GTI
    Jan 2012
    hmmm mk3 is a new beast it seems!
    also, i think you have the mount for the plug on the wrong side of the hitch mount. it should be bolted onto the other side, but still facing left
    May 2012
    I thought that too as I had seen others but it Dosnt reach. And the cut out is bigger on the left. I tried a couple of ways to try make it fit but nothing worked
    MY12.5 Polo 6R GTI
    Jan 2012
    Quote Originally Posted by lunchboxGTI View Post
    hmm perhaps they are supplying the wrong part with the kit?
    i need to take mine off, or just leave it where i left it and deal with it. if it doesnt fall off and doesnt foul anything, i really dont mind where it is
