For those who haven't seen it, this is what the factory towbar looks like... Check posts 113 and 119.
Skodas and tow bars
Correct smart1, the factory tow bar prep includes a rear bumper with cut out, wiring to the rear, and a larger radiator with 2 fans for efficient cooling.
Skodas and tow bars
2012 MY11 Cappuccino Superb Elegance, TDI. (Gone)
2014 MY14 Race Blue Octavia Ambition Plus wagon, TSI, Tech Pack. (Wife's)
2014 MY14 Cappuccino Octavia Elegance hatch, TDI, Sunroof, Tech Pack, Towbar. (Gone)
2017 MY18 Lava Blue Superb wagon, 162 TSI, Sunroof, Tech Pack, Comfort Pack, Cream Leather, Towbar (Mine)
I have a feeling all Octavia's came prepped. Oirs has the double fan radiator, I think they all did and is a mk2.
installed the wiring and tow module tonight. fairly easy to be honest. VERY glad my car had tow prep.
coded fine and passed diagnostics with the westfalia branded module
ill post photos after the towbar is installed on saturday.
towbar install was fairly straight forward. removing the crash bar was fun. didnt see the bolts until some of the panel sealer was removed.
had to trim about 40mm extra from the bumper to get it to fit. but as i already had tow prep, it wasnt a huge job.
getting the bumper off and on was probably the most difficult part.
will post pics later
Neck won't fit in the styro form, only the genuine Skoda ones does. No biggie.
My bar didn't come with the plug mount either. Chase that up with Tammy.bugeja@evt-automotive.com.au. Should send it at no charge.
You should not have needed to remove any more bumper for the bar. The key is to install the bar as far forward as possible within the long bolt on slot. Went to put bumper back on and found this out. Slid it in as far as I could and presto. I did need to cut off one of the rear lower bumper screw mounts to make way for the plug to swing up and out of the way. Quick and easy
