Results 1 to 10 of 144
Thread: Time to get serious!!!
    Sep 2008
    Its a pity thought that both those as final upgrades are bloody expensive with the install of an LSD costing the same if not more than the LSD itself and the KO4 kit cost plus the install and then retune. Sigh
    Jul 2011
    Burwood, VIC
    yeah I spoke to Dean today about stage 3 and he said I'd need to get a diff. So how much is the diff then ??
    hmmm, I wonder whether there's any insurance issues with putting LSD on a car that wasn't designed with it ..
    - 2006 Audi B7 RS4 sedan, black, APR supercharged
    - 2008 Audi B7 RS4 avant, silver -- 2002 Audi B5 S4 vagwagon, ming blue
    - MY12 OCTAVIA vRS Wagon | DSG | revo | Eurojet DP | Milltek catback | KW V3's | 18x9 -45 Rays VR G2's | 18x8.5 -45 A8 Flat Fives | Kumho KU36 245/35 | Superpro ALK | ECS Stage 3 BBK | ECS eng mount | ITG Maxogen | DTM front splitter | SB
    Oct 2010
    Narellan, NSW
    Probably should be alright. I am with NRMA and they state that as long as the car past roadworthy, any modifications can be carieed out. Is it peloquin LSD?
    MY10 Occy vRS \\ GIAC Flash Tune \\ 19" VMR v713 \\ It's a Skoda. Honest.
    Thanks for the props
    didn't take much to modify and it was perfect straight off the bat thanks to Tim's measurements! I was just the mug who TIG'd it
    Always happy to help. Car sounds dam mean now!
    Get on the Eurojet bandwagon fellow Skoda Octavia owners, an affordable and quality downpipe!
    Oct 2010
    Narellan, NSW
    What needed to be modded on the downpipe in order to make it fit?
    Sep 2008
    Quote Originally Posted by dru View Post
    The downpipe cam is 3 sections.
    1. part that attaches to the turbo
    2. pipe with high flow cat
    3. connecting pipe between high flow cat section and the reducer to attach to factory catback via slip joint
    Now, Part 1 was unmodded. But what required modding was some shortening and cutting off of the end connection flange of one end of section 2 and cutting off the reducer from section 3 which was then tig'd onto the cut off bit of section 2 hence resulting in a final kit of 2 sections rather than 3. Everything was cut and welded to precision milimeters all thanks to Tim and Josh. Awesome work.
    P.S. The down pipe is as quiet in cabin as the factory one with only difference being the very slight extra burble outside. No drone what so ever. So if you want a stealth system then the eurojet downpipe is the way to go. Check it out and get one for yourself from Tim at Dub Ad·dic·tion [duhb uh-dik-shuhn]!!!
    Sep 2008
    Oh man just heard from DNA tuning that I need the fuel pump to really make it worthwhile for the retune. I guess I'll have to get the Autotech fuel pump internal upgrade sooner rather than later. Otherwise I can still get stage 2 tune but just not 2+.
