Results 1 to 10 of 137
Thread: Things I'd like to improve on my Skoda:
    Apr 2009
    Northern Tasmania
    I wouldn't mind if they could work out a (neat and clean) way to get at the spare wheel from underneath rather than having to unload everything.
    2008 Skoda Octavia Elegance TDI 4x4 wagon
    Bluefin 132Kw/385Nm, Racechips Response Control, Haldex Performance controller, H&R anti roll bars, Koni FSD shocks, SuperPro control arms & ball joints, subframe & gearshift mods, Full Dynamat interior, Polk Audio sound, Columbus, Bluetooth, MDI, parking sensors, camera. BBS SR 18x8" w/ 225/40xR18. 3M Crystalline tint.
    Apr 2012
    Cherrybrook NSW
    +1
    Even worse if you have the heavy rubber boot mat fitted, which has to be lifted out, it's too stiff to roll up out of the way.
    The spare is a bitch to lift out too, given that it sits quite low in the car - not at all good for your back.
    One of the best systems I've seen was on a Peugeot 504 which had the spare wheel sitting in a cradle under the boot . It had a release handle inside the boot, which when pulled, allowed the cradle to drop down and the spare slide out toward the rear. Getting the wheel back into it however, was a different story! The only way to swing the wheel and cradle back and locked into position was to lift it back up with the jack! Still way better than having to unload everything to get the spare out and then re-load afterwards.
    Bowral, NSW
    My Kia Sorento had the same system as most utes.
    You pop a plastic cover and use the tyre iron to wind the spare down under the car onto the ground. Then you unclip the chain and take the spare out.
    Pop the centre cap, clip the chain back in and wind it back up to store the spare back up under the car.
    Once I actually worked out the system, it was amazingly easy! Even when stressed and yelling expletivs at inanimate objects!
    2012 Octavia vRS TDI. Darkside big turbo, 3bar tune, other stuff. 200kW/650Nm.
    1990 Mk1 Cabrio. 1.9 IDI w/ 18PSI.
    1985 Mazda T3500 adventuremobile. 1973 Superbug. 1972 Volvo 144 in poo-brown.
    Not including hers...
    Apr 2009
    Northern Tasmania
    Quote Originally Posted by k_rider View Post
    +1
    [snip]
    One of the best systems I've seen was on a Peugeot 504 which had the spare wheel sitting in a cradle under the boot. [snip] The only way to swing the wheel and cradle back and locked into position was to lift it back up with the jack! [snip]
    Don't tell us - the jack was at the bottom of the boot?
    I have the rubber mat (one of their better accessories) and the carpet version (which is a bug*er to get out because there is nowhere to grab hold of it).
    Apr 2012
    Cherrybrook NSW
    Quote Originally Posted by wfdTamar View Post
    No, the jack and handle/wheelbrace were actually stored in the engine bay! Clipped onto the back of one of the strut towers. Now that was "simply clever"!!
