Results 1 to 10 of 15
Thread: Driving 147TSI DSG
    Mar 2013
    Shire, NSW
    Driving 147TSI DSG
    Hi all,
    Ok after now having driven my near new VRS 147 TSI DSG for 2 weeks Im starting to take notice of the shift habits of the DSG.
    Ive come from a 2001 Holden Wagon V6 Auto so BIG change, love the DSG in the VRS! its a gearbox for me and the wife! However I've noticed when driving in D and slowing down to a near stop mainly on a slight incline <5km/h then accelerating again DSG will stay in D2 when I feel it should shift back to D1. The only reason I feel this is that it has the same engine feel as if I was driving a manual and riding the clutch in second gear rather than first.
    Can anyone share their experiences or thoughts on this with the 147 TSI DSG, does your DSG shift back to D1 earlier or is what I'm experiencing the norm, maybe its just that I'm paranoid or something knowing the potential problems with a DSG box.
    MGT
    Jul 2010
    that's normal.....i believe.
    mine stays in d2 for as long as it can before 'having' to shift down to 1st.
    if i try to do the exact same thing (same intersection, same speed) in manual mode, it will most certainly drop down to 1st much earlier.
    in start stop traffic, mine likes to stay in d2 whenever possible.
    MY17 Superb 162TSI, Business Grey, Tech+Comfort Pack, APR ECU+TCU Stg 1, SLA, Rieger Splitter + Side Skirts, Eibach Pro-Kit Springs, Hardrace Swaybar, TPMS
    May 2012
    Lyndhurst Victoria
    I agree that this appears to be normal.
    It does irritate me when you try to make a swift getaway from a roundabout or give way sign and it feels exactly like a slipping clutch. I have kind of gotten used to simply tapping the down paddle when I think it might happen.
    I am looking a Viezu tune at some point and with the tune it comes with a basic DSG remap that can be tailored to your driving style. I want this purely for the purpose of more rapid kickdown through the gears.
    *****CURRENTLY FOR SALE***** See Sale thread
    Candy White MY12.5 Octavia VRS TSI DSG wagon.
    Black Plasti Dipped wheels, grille surround, roof rails and badges. Lowered 20mm, torque arm insert.
    Mar 2013
    Shire, NSW
    Ok thanks guys,
    Yeah had the same thing happen at a round about today will have to use the paddles more in that situation, loving the DSG though don't think I will ever go back.
    Apr 2010
    The DSG will never shift back to 1st until you're pretty much stopped.
    The behaviour can be changed... for a price:
    http://www.vwwatercooled.com.au/foru...ram-73662.html
    With the upgrade on my car it now shifts back down to 1st at around 17kph
    Jan 2012
    yup its normal!
    using S mode will shift into 1st around 8-15km/h.
    if you want first gear, hit the paddle and force it to 1st
    Dec 2012
    Sutherland Shire, Sydney
    Quote Originally Posted by MGT View Post
    II don't believe it is slipping the clutch at all
    Remember it's a turbo, much more torque over a wider rpm range
    Jun 2008
    Ringwood, Victoria
    Driving 147TSI DSG
    Quote Originally Posted by Martin View Post
    Not as you're slowing down but as you go to take off again, it will be slipping quite a bit. Try taking off from 5kph in second in a conventional manual without plenty of clutch slip.
    As Ryan has pointed out, Harding Performance now has a DSG tune available for the DQ200 dsg in your car which fixes this issue. What you are describing is the number 2 clutch's worst enemy and why they burn out so quickly. The other situation that is bad for them, is peak hour traffic, period. So much so that if you buy a dq200 equipped vehicle in the Netherlands I think it is,VW won't cover the dsg under the warranty the vehicle is to be used as a taxi because the genius that designed this gearbox for the advantages of a dry clutch, obviously never tested it in real life situations like 99% of the buyers drive in because why else do the clutches get fried so easily, even in the low powered vehicles with this gearbox?! The clutches get too hot and once they get over 160 degrees (from memory) they're pretty much toast.
    Dec 2012
    I drive my DSG in rush hour traffic everyday - I've never felt it slipping when pulling in second from a crawl
    With the ECU in stock mode the engine will labour on a low rpm pull in 2nd
    With the ECU In stage2 mode it will pull smoothly from ~1200 rpm
    With both there is no feeling of a differential between road speed and engine RPM
    (Firmware versions may have a lot to do with it)
    I am however considering the Harding DSG firmware - but for other reasons (like the stage2 torque rating)
    Jan 2012
    the DQ200 is the 7speed dry-clutch DSG, we have a DQ250 6speed wet-clutch.
