Results 1 to 10 of 15
Thread: vRS petrol - Manual - Servicing 60k - be wary
    Oct 2010
    Gold Coast, QLD
    Hi all,
    I have been ringing around to skoda dealers to get my car serviced.
    The price has been varying between $800 and $950
    Is that what people have been paying?
    According to my service schedule its a inspection service plus pollen filter change.
    Things to look out for (according to the book)
    Brake fluid changed at 3 years then every 2 years afterwards
    on the Tsi/147 Motor plugs changed every 90k not 60k.
    My11 Octavia VRS Tsi
    Rockford splits in front - Tinted Windows - Viezu Perfomance tune - K&N Panel filter
    Mar 2012
    Cronulla, NSW
    Don't get it done at a Skoda dealer. They changed everything regardless of whether it needs to be changed or not.
    A typical euro servicer or VW specialist will be able to do the service for around $250-odd then tell you what needs replacing and ask if you want it done. They usually can use OEM parts to avoid voiding the new car warranty (if it is still active)
    I'm about to get my 30k service done and VW dealers are quoting me $750. Private servicers are quoting as above.
    My plan is to get the expensive services (30k, 60k, 90k etc) done at private places and the cheaper ones (45k, 75k etc) done at VW dealers to get the software upgrades for DSG, ECU etc.
    Current Ride: Golf GTI Mk7 MY2014|DSG|Carbon Steel
    Previous Ride: Polo GTI MY2012|DSG|RNS510|Shadow Blue|Lenso GF7 18” rims
    Instagram: @lemonskin
    Oct 2009
    Mitchelton, Qld
    Quote Originally Posted by Lemonskin View Post
    Couldn't agree more. Dealer servicing is just a license to print money.
    Erskineville, NSW
    Quote Originally Posted by andymarc View Post
    Hi all,
    The dealers have a standard list that has no resemblance to the owners manual. Of course, the dealers will assume you are an ignorant git & that they know best.
    When I was shopping around for my 60k I had quotes in the same range (possibly higher) and they also wanted to charge for tyre rotation & other stuff that I can't recall. Best dealership quote was a rural dealer (about the same distance from work as the nearest metro dealer) at ~$600 including spark plugs & brake fluid flush.
    In the end I got it done at a specialist independant minutes from work & it was cheaper as well.
    I don't follow the schedule religiously & bring some things forward slightly. Pollen filter is changed every 30,000km (about 15 months for me); brake fluid every 45k (22months); Air filter every 45,000km; Spark plugs were done by the book at 90k.
    Oct 2009
    Mitchelton, Qld
    I don't get this? Don't they have to take the wheels off to check the brakes etc? Hence tyre rotation costs nothing!!!
    Erskineville, NSW
    With the more open alloy wheels you can see the brakes through the wheels & from underneath - enough to know if they are OK or not.
    I never used to take the wheels off unless I had to. I even had a go/nogo gauge made of a hacked-up brake backing plate welded onto a rod that I would slip between the spokes of the wheel - if the backing plate slipped in-between the disc & the real backing plate then there was probably enough life left to make it to the next service in 6 months time. That probably wouldn't work with todays extended service intervals.
    Lost all those "special" tools when thieves broke into my garage.
    Dec 2008
    Sydney/Canberra
    Spark plugs are every 60,000klms.
    The book is way off.
    '07 Transporter 1.9 TDI
    '01 Beetle 2.0
    Dec 2012
    Gold Coast, QLD
    Re: vRS petrol - Manual - Servicing 60k - be wary
    Great thread. Thanks for the tips.
    Sent from my ASUS Transformer Pad TF300T using Tapatalk HD
    NOW: 2018 MY19 Kodiaq Luxury and Tech Packs: 132kW Petrol 7DSG Sunroof and Ivory Leather
    HISTORY: 2012 Fabia RS (FOR SALE) ; 2013 Fabia RS (SOLD); 2015 Octavia RS 135TDI (SOLD)
    Erskineville, NSW
    Quote Originally Posted by Umai Naa!! View Post
    Seems a common theme that Australia wants to change these things much earlier than the rest of the world.
    My plugs looked quite nice at 90k. Gaps were at spec, colour was good, no odd visuals. The new plugs made absolutely no difference.
    Adelaide hills, SA
    Yes, the platinum plugs should be good for 100,000km at least. But even if they look OK after +100k km, the porcelan part of the plug will be affected by the vibrations and the high temperatures, also the seal between the metal part of the plug and the porcelan doesn't last forever.
    I would always change the platinum plugs at 100k km.
    haven't said that, even Subaru has 50k km service interval on their turbo engines.
