Results 1 to 10 of 17
Thread: Switched from 0W-30 to 0W-40 oil
    Dec 2012
    Sutherland Shire, Sydney
    On my last oil change I changed from using 0W-30 oil to 0W-40
    I've done 2,500km since then, so far so good...
    The engine is a little bit quieter, the oil consumption is a little lower
    I am trialing a similar thing on my mates MK5 GTI. I am his resident mechanic, so i do all the oil changes etc and basic maintenance. We have used various 5w-30 VW approved oils - from Shell Helix Ultra Extra, Castrol Edge (not VW approved actually) and more recently Penrite Enviro+.
    Regardless of oil brand used, the car drinks about 500-600ml per 1,000km and therefore goes through several litres of oil between each service (services done at 10k intervals because he couldnt care less) which is annoying.
    Did a service on his car about a month ago and decided to try Penrite Enviro+ in a 5w-40 weight. So this oil is a little bit thicker when hot. The 5w-40 is actually about $20 cheaper than the 5w-30 so if it works out to reduce the oil consumption then its a win win situation.
    This stuff: http://www.penriteoil.com.au/product...id_products=13
    Melbourne, Vic
    Quote Originally Posted by Martin View Post
    I assume it is still 504.00 spec?
    2001 - A4 B6 1.8T Sedan Manual - (sold @ 254,000km)
    2008 - A3 8P 1.9tdi Sportback Manual - (sold 90,000kms)
    2013 - Octavia RS wagon - 1z - Race Blue - TDI - 6M - Leather - MDI - Whispbar S44W - LED interior kit - RVC forward?/retrofit - Mk3 gear shifter
    2021 - Q3 S-Line wagon - F3 - Daytona Grey - Westfalia towbar - no other options available.
    Dec 2008
    Sydney/Canberra
    Nope, it isn't.
    '07 Transporter 1.9 TDI
    '01 Beetle 2.0
    Dec 2012
    Ah yeah, it's actually 5W-40
    Quote Originally Posted by spud75 View Post
    It's 502/505 spec
    Quote Originally Posted by Diesel_vert View Post
    Quick link: Link to VW approved oils
    Although VW 502.00/505.00 or VW 502.00/505.00/505.01 lubricants are acceptable to use on vehicles with fixed service intervals without a DPF, I believe that it's better to use VW 504.00/507.00 lubricants in direct-injection engines, as the following link will demonstrate:
    ACEA Conference Papers - The Lubrizol Corporation
    Download the conference paper titled, "Lower SAPS Engine Oils - Essential components in maintaining vehicle emissions compliance", dated October 2006, and head to page 19 & 20.
    In direct-injection engines, fuel is injected directly into the combustion chamber, which bypasses the inlet valves and is unable to clean them. Using a low-SAPS or mid-SAPS engine oil may reduce the rate of deposit formation on the inlet valves (or so the theory goes).
    Penrite state that 5w-40 is a low/mid SAPS oil and is designed for use in modern direct injection engines.
    Looks much the same stuff as the Enviro+ 5W-30 which is 504/507
    Lucas, my TSI engine was drinking 750ml per 1000km and that's now down to about 500ml per 1000km (maybe/approx)
    Adelaide hills, SA
    You could also try Mobil1 5W50
    Dec 2012
    That could be awesome for a little more protection on hot track days - thanks!
    Nov 2009
    Illawarra NSW
    My 09 vRS has never used a drop between oil changes. I believe the cost for VW 504/507 approval from VAG is about $650 K for 3 years. Nice money earner for VW just to put a stamp on your bottle. I m sure plenty more oils meet the criteria but refuse to be blackmailed.
    2014 MY14 Corrida Red Elegance Wagon TDI
    2009 MY10 Race Blue RS Wagon TSI 6 sp. manual. (Gone)
    2011 MY12 Yeti 77 TSI DSG.
    Jan 2011
    Brisbane - QLD
    Has anyone tried the penrite racing 10w-40? VW502.00 oil.
    It claims to be a mix if group 4 & 5 base oil.
    Sent from my GT-I9300T using Tapatalk
    MINI Cooper S Clubman - FWD
    Jul 2010
    Quote Originally Posted by Antiplastix View Post
    +1
    My oil level hasn't dropped between services, and I check the dipstick once a month.
