2012 Octavia vRS TDI. Darkside big turbo, 3bar tune, other stuff. 200kW/650Nm.
1990 Mk1 Cabrio. 1.9 IDI w/ 18PSI.
1985 Mazda T3500 adventuremobile. 1973 Superbug. 1972 Volvo 144 in poo-brown.
Not including hers...
Finished installing the driver side under seat box (my car already has the passenger under seat box)
It's not a good fit on two counts
It does not merge into the existing seat wrap around trim well, there is a 1/2 cm gap at least, hard to notice but I know it's there
The rear mounting holes are in the wrong place (so it's not a Soka item) - but there is a work around
I'm happy to have the box but if I had known about these issues I may not have bought it
+1
It's a pig to fit eh? Did you end up lifting the seat out or leaving it in place? As I said to you on Saturday's run, I fitted the box with the seat in place - I know now that that was the hard way!Did you make sure the tabs (can't remember if they're on the box or the trim) are clicked into their respective slots all the way? You need to apply quite a bit of pressure to get them home.
