Hi, anyone had this issue. Had the car 3 weeks and twice now I have stopped on a slight incline and stop/start has stopped the engine and when I have taken foot off the brake I start rolling back. I found that the engine has stopped completely and I have to put the car in park and start the car manually. Thankfully it hasn't been a big problem because it has happened whilst entering my driveway/garage. Thought I would post this here in case it is a known issue before I talk to the dealer tomorrow. I did see something about a problem whilst in ECO mode but I am in Normal mode.
I don't think whether I want it activated or not is the issue here. The issue for me is/was whether there is a design fault that is causing this or it is just a quirk. I could just turn it off but that wouldn't answer my question. Thanks wingzee for your comment on your experience with this. I will watch with interest as to whether it occurs again to me or was just 'one of those things'![]()
Sure thing. Wasn’t concerned about the issues as I thought it’s among the quirks of a start-stop system (this is my first car with a start-stop). Good that you brought this up so I know that I am not alone.
Slightly off topic but I already had errors thrown from the Blind Spot Monitoring + Rear Cross Traffic Alert at about 800kms. Just appeared outta nowhere saying “Systems currently available”.
Nothing a OBDeleven can’t solve but does concerns me given the car was than a month old back then!
Tks for that info. I check with the OBDEleven every weekend and have found that I am getting an error of "current too high" in one of the modules but can't remember which one at the momentDoesn't seem to be affecting anything though so I just keep clearing it
anyone getting constant errors and system failures should see a dealer ASAP
don't clear the errors, leave them so they can see the failures. even if the system is working ok again, leave the errors there.
u have an issue with ur start/stop system - i would get it checked out by the service dept immediately.
the car should not roll-back, or die after the start/stop has been active!!!
i haven't come across this behaviour, even on an incline.
i do have auto-hold-brake switched on all the time though - 1st tap on accelerator to wake the car from start/stop, 2nd tap to disengage auto-hold and get moving.
MY17 Superb 162TSI, Business Grey, Tech+Comfort Pack, APR ECU+TCU Stg 1, SLA, Rieger Splitter + Side Skirts, Eibach Pro-Kit Springs, Hardrace Swaybar, TPMS
