Speedos in AUS must comply with ADR rules which put simply say that they can read up to 10% + - 4 higher than actual speed at 100kph
They may NOT LEGALLY show LESS than actual speed. If yours is reading less than actual, someone has fitted wheels of a much larger overall diameter to do that.
Our Polo reads 7 over at 100kph and to correct it to show 100 at 100 would take a diameter of 46mm more which is illegal in Queensland
I suggest you take it back to where you got them and point this out.
We have not been able to adjust the speedo calibration on either car using VCDS
Here is the best comparator to find out
Custom rims, wheel tire packages for your ride - RIMSnTIRES.com
Put the old size and the new one in and it will tell you how speedo will read Dont worry about offset it doesnt make any difference
