Results 1 to 4 of 4
Thread: Soft return grab handle mod
    Erskineville, NSW
    My kids & mother have the annoying habit of using the grab handle above the door & letting go so that it bangs noisily - over & over. Kids are kids & Mum has dementia so no point telling them to stop.
    I bought some handle dampers off AliExpress (can't see them on ebay). They were ~AUD14 for 4. This seller does them 6 for $14 - I have no idea why as you only need 4 & once you do the mod you'll never get them apart again without demolishing the pivot pin. Buy 2 lots (12 & you'll have enough for 3 cars.
    The instructions are in the listing. The only thing I did different was remove the screw cover as it makes access easier. The screws are Torx (same size as the common one on pushbikes T4?) not triple-square.
    It will take you 30 minutes tops & works perfectly.
    Recommended for those that like to fiddle.
    Also, the R8 coil packs - just do it!
    Jul 2013
    Caulfield, VIC
    I dont need this but its cool what people think of!
    What other cool stuff is on this site???? Or anywhere. I love tacky mods :p
    www.TheRapidWrench.Melbourne
    The convenient, professional and affordable mobile bicycle mechanic that comes to you!
    My RS build thread
    Erskineville, NSW
    If you want tacky mods then AliExpress is the place to look!
    They've gotta add at LEAST 10kw each, almost as much as valve stem covers!
    I don't have the problem of people using them yet but good to keep in mind should they start snapping away back there
