Enabled using OBD11, using VCDS instructions I found elsewhere - can't remember exactly where that was sorry, so I can't credit the original post, but if I find it again, I'll post the link for courtesy.
At first, I didn't think it had worked, as I couldn't see anything obvious on-screen or where to view it, but it's actually hidden in the "Car" button, under settings.
VCDS Instructions:
Controller 5F (Information Electrical)
10 – Adaptations
Channel: (81) Car_Function_Adaptations_Gen2-menu_display_compass: Active
Channel: (83) Car_Function_Adaptations_Gen2-menu_display_compass_over_threshold_high: Active
Channel: (41) Car_Function_List_BAP_Gen2-compass_0x15: Active
And that's it!
There's a lot of other options inside that Car_Function......menu_display folder.... I haven't played around with anything else, but I suspect there may be other wanky things to enable in there, for other models.
Presumably this adaptation, while listed where I found it as being for Superb, will probably also apply to Tiguan/Toe-rag/Kodiaq models that are "offroad" capable.
