Page 6 of 17 FirstFirst ... 4567816 ... LastLast
Results 51 to 60 of 168
Thread: Skodas and tow bars
  1. #51
    Sep 2014
    Could you have done it with a 13 round to 7 pin round adaptor (about $20) and a 7 pin round to 7 pin flat adaptor (another $20)?
    Did you tear the spare wheel well apart & look in the deepest darkest confines of the glovebox & the storage area under the passengers seat?
    Slightly better value for others in the same boat
    Trailer Plug Adaptor 13 Pin Round to 7 Pin Flat
    I did and ordered of fleabay as well but need to have it before the weekend or no track day which I'm within cancellation deadline for.
    good find on that I scoured google and couldn't find anything
  2. #52
    Feb 2008
    Quote Originally Posted by Gerrycan View Post
    Would it be impolite to ask how much your Westfalia towbar cost? Did you install yourself or was it done professionally?
    Got mine from PF Jones Witter Tow bars, Westfalia Towbars, Price Promise all Tow bars. Eberspacher Main Dealer
    All up including the dedicated wiring about $800.I did the install myself.
    Westfalia Australia will soon have this same bar available here,
    but more expensive than the one I got even including the postage ,which took three days from ordering to arrive at my house!
  3. #53
    Jul 2014
    Quote Originally Posted by R1 Crasher View Post
    Thanks, that is much more reasonable.
  4. #54
    May 2011
    Albury / Wodonga
    So has anyone found a 50mm square hitch option for the new Octavia? My wife wants a Thule swing away bike carrier, the type that swings with the bikes on it as opposed to tilting out of the way when empty, and they only work on hitch type bars. Can't fit them on a ball. Dealer says square hitch types don't comply with ADR for what it's worth. No idea if that's true or not. He is a car salesman.
    Looking for:- RS4 B7 Avant.
    Current:- Amarok V6 Sportline; Mazda CX-9 Azami AWD
    Previous - Mk 6 R manual; Mk 7 R manual; Passat 130 TDi Wagon. Mk 7.5 Wolfsburg Wagon.
  5. #55
    Oct 2009
    Mitchelton, Qld
    Quote Originally Posted by Paul_R View Post
    I've got a 40mm square hitch HR towbar on my Mk 2. But as I found out, the hitch bike carriers don't fit this as they use the 50mm square. You'll struggle to get a 50mm square hitch on an Occy as these are the higher load rated hitches for which the Occy isn't designed for. HR wouldn't even contemplate putting the 50mm hitch on mine and said only the Load Class 2 hitch (I think its class 2 - 40mm) is the only compliant towbar (square hitch) for the Occy.
  6. #56
    Erskineville, NSW
    I can't see how it can't comply with the ADR. Don't most of the Heavy Duty HR towbars come with 50mm square hitches? That's what my wife's 18 month old Craptiva has.
  7. #57
    Oct 2009
    Mitchelton, Qld
    My understanding is that the Occy tow limits set by Skoda determine what HR can and can't put on the car. Skoda don't rate the Occy for HR's 50mm hitch. They only rate the Occy for the 40mm hitch (lighter ball weight and unbraked towing capacity).
    This is what HR would only install on my Occy
    Reese Light (RL) Towbars Class 3 - Reese Light (RL) Towbars Class 3 - hayman reese
    Most larger vehicles get this HR installed, which is the 50mm hitch which is what most if not all hitch type bike racks fit.
    Heavy Duty Towbars Class 4 - Heavy Duty Towbars Class 4 - hayman reese
    And the HR webiste confirms that the above light towbar is the only part they will sell/install for the Occy.
    Hayman Reese - 02729RLW - haymanreese
  8. #58
    Apr 2009
    Northern Tasmania
    There's a Westfalia bike carrier (BC 60) that fits on the gooseneck ball type tow bar. Swings down and has light and number plate bar. Pretty sure I found it from OS for around $500-600.
    Cycle Carrier BC 60 – Westfalia-Automotive
    One Australian place that has them (not sure of price, I think around $900!)
    Westfalia | Melbourne Towbars
    2008 Skoda Octavia Elegance TDI 4x4 wagon
    Bluefin 132Kw/385Nm, Racechips Response Control, Haldex Performance controller, H&R anti roll bars, Koni FSD shocks, SuperPro control arms & ball joints, subframe & gearshift mods, Full Dynamat interior, Polk Audio sound, Columbus, Bluetooth, MDI, parking sensors, camera. BBS SR 18x8" w/ 225/40xR18. 3M Crystalline tint.
  9. #59
    May 2011
    Albury / Wodonga
    I thought as much. Thanks. I'll have to look for another bike rack option that can tilt or swing off a ball fitting. Most tilt options say the bikes must be taken off first, as does the Thule one, but then the instructions go on to describe how to do it with the bikes on. It does have a picture of an arm with very big bicep beside that diagram though...
    BTW I need a 4 bike rack.
  10. #60
    Erskineville, NSW
    Ah.
    So the salesman made a statement of fact but wrongly attributed the reason why.
