Page 10 of 17 FirstFirst ... 89101112 ... LastLast
Results 91 to 100 of 168
Thread: Skodas and tow bars
  1. #91
    Apr 2009
    Northern Tasmania
    Very tight fit to get to smaller bike on. I had to lift the seat and even then it a hell of a struggle. I have to hold the bike in place, push down on the rubber mounts, get the cross bars in place, then clip the cross bar on.
    Skodas and tow bars-2014-11-05-12-35-31-jpg
    (I put the foam knee pads in there to lift the cross bar up to show how much room there is).
    Skodas and tow bars-2014-11-05-12-38-08-jpg
    Really difficult to mount both bikes in this arrangement.
    Skodas and tow bars-2014-11-05-12-38-52-jpg
    2008 Skoda Octavia Elegance TDI 4x4 wagon
    Bluefin 132Kw/385Nm, Racechips Response Control, Haldex Performance controller, H&R anti roll bars, Koni FSD shocks, SuperPro control arms & ball joints, subframe & gearshift mods, Full Dynamat interior, Polk Audio sound, Columbus, Bluetooth, MDI, parking sensors, camera. BBS SR 18x8" w/ 225/40xR18. 3M Crystalline tint.
  2. #92
    Apr 2009
    Northern Tasmania
    Skodas and tow bars-2014-11-05-12-52-15_2-jpg
    Finally got them on, but hardly any ground clearance.
    Skodas and tow bars-2014-11-05-13-14-40-jpg
    Put the small bike next to the car. They go on a bit easier, but still bad ground clearance. I could take the front wheels off, but even so the ground clearance will not be good enough.
    Skodas and tow bars-2014-11-05-13-45-13-jpg
    Here’s what happened going out my driveway gutter for a short test drive. This is a very shallow gutter, but still the bikes hit the road and the bars almost cracked the rear window. I’m not sure if that’s a permanent mark the handlebars made in the window or the finish from the handlebar end caps.
    Skodas and tow bars-2014-11-05-13-48-35-jpg
    Finally - take the bikes front wheels & mudguards off, raise the seats to get the bikes on the racks, then lower the seats to raise the rear wheels off the ground. Turn the handlebars sideways. Then try to get the tight light board arms in the holes. There is NOTHING Xpress about this product. Except maybe putting the rack on the car.
    It is really not suitable for modern mountain bikes.
    The photo makes it look like the wheels stick out miles - it's only about 150mm at most.
    Skodas and tow bars-2014-11-05-14-17-10-jpg
    Skodas and tow bars-2014-11-05-14-22-06_2-jpg
    So yes, it’s a working bike rack, but it’s a right royal pain in the bum to get the bikes on and off - and it has to be done to get access to the boot (which I did know, but I was under the impression it was easy). Should have got the Westfalia BC60, or Thule Euroride 940 (though this has put me off Thule stuff).
  3. #93
    Erskineville, NSW
    I'm sure you've tried it a million ways but what happens if you remove the font mudguard (you don't need a front guard anyway) on the big bike & mount the arm in the V between the fork & the bottom frame rail? That will lift the front up a lot higher & get the handlebar away from the window.
    Sorry it hasn't worked for you. I think I tried 3 different hanger style racks (two owned by friends) before i bit the bullet & found a workable ride on tyre mount solution.
    One of the guys I work with has the Thule 912XTR ride-on. It's really good & even easier to use & mount the bikes than my Torpedo7 unit.
  4. #94
    Oct 2009
    Mitchelton, Qld
    Geezus that looks like a mission. Thule really haven't considered different bikes much have they!! Why do they have the horizontal bars so far apart? I don't get it?
    I'd be selling that one on ebay real soon and going for something that fits your particular bikes way better. But I see from your euro style of towbar your bike rack options are limited.
    BTW I think the way you've got the bikes in your 2nd last pic above might be considered illegal? Can you have objects protruding 150mm out last the width of your car like that? I know they don't allow any width overhang on things on your roof.
  5. #95
    Apr 2009
    Northern Tasmania
    You missed where I said I take the mudguards off (easy - just press a tab both sides of the fork and they slide off). I reckon lifting the big ike up like you suggest will throw the front wheel out even further and lower the rear wheel too much (I'll have a go though). Might work if I also put the seat rack arm under the top bar of the bike (lift the whole bike up a lot).
    This rack would work ok for older style road bikes that have plenty of room under the top bar (and old school size bars). Aluminium frames mean bigger bar sections which complicates things.
    There are a few options to fit the Euro bar (mentioned some earlier). I think I'd go with the Westfalia BC 60 if I want something better.
    That second last pic is a bit fish eye lens-ish. It doesn't actually look that bad. Though it does protrude out about 200mm when I looked from the front.
  6. #96
    Jul 2014
    Since you only have two bikes, have you thought about putting them inside the car?
    What I do is take off the front wheel and saddle stem of each bike, a two minute job.
    Then I put down the back of one side of the rear seats, usually the double but I can get away with the single (extend the headrest beyond the seat to get it lying flat.
    Put the bikes in inverted so the handlebars support them upright. One facing forward and one back and overlapping.
    Secure with bungies and padding if necessary.
    Attached is a video review of Polo and Jazz, halfway through they show three mountain bikes fitted inside the Jazz and seating three people.
    Honda Jazz v Volkswagen Polo comparison review
  7. #97
    Apr 2009
    Northern Tasmania
    Yes, I was doing that until the rack arrived. I want to have them on the outside for travelling (when the car has other stuff in it) Also so I don't have to worry if they're muddy.
    Someone at Thule Australia suggested turning the rubber mounts on the rack arms (didn't know they did turn) and mounting the smaller bike higher up under the lower frame bits.
  8. #98
    Jul 2014
    Quote Originally Posted by wfdTamar View Post
    Yeah, I forgot it sometimes rains in other parts of Australia.
  9. #99
    Apr 2009
    Northern Tasmania
    Ok, it worked without the cross bars/adaptors and turning the rubber mount things, but the weight of the bikes pushes the two arms apart then it's a bugger to push the light board into them (which has two arms that go inside the racks arms).
  10. #100
    Sep 2014
    Hi Guys,
    I have the genuine 13 pin to 7 pin cable, but it wields out with my LED lights and the lights just flash (brake light works indicators don't), has anyone encountered this before? is it something that can get coded out or do I need another adaptor?
