Compared to the PE2, you should expect even more grip, better handling, shorter braking distances and similar wear rates from the PSS. Noise should be similar to the PS2/PS3, which aren't known for being excessively loud anyway.
If you are dead set on getting the PS3, you should seriously consider getting the PSS from Tire Rack - worst case scenario, they may end up being the same price as the PS3 locally, but you'll end up with a better tyre (in terms of performance).
