Page 3 of 36 FirstFirst 1234513 ... LastLast
Results 21 to 30 of 354
Thread: Skoda RS replacement tyres - interesting
  1. #21
    Hi All,
    Drew newbie to the forum here.
    17000kms on my 09 vRS wagon. picked it up second hand recently, not looking forward to replaceing tyres on it. I know I'll have to do it within the next 12 months. rear tyres are badly scolloped on the inside. leading edge of tread block high, trailing edge low. a bit too buggered to put on the front me thinks!!! Prev owner never rotated tyres and tyre pressures were very low when i got it.
    They're Dunlop SP Sport Maxx on it now, i'd be interested to hear comments from people who have driven on these and are able to compare them to the Michellin Pilot Sports or Conti Contact Sports.
    Also, the missus is due for tyres on her Jetta very soon too. Currently has the Michellin energy 205/55/16s on it. Tempted to keep with those. Anyone have any other recommendations for 16"s?
    cheers
    Drew
  2. #22
    Jul 2010
    instead of 225/40-18, can we fit 235/40-18?
    Specification--Sidewall--Radius--Diameter--Circumference--Revs/Mile--Difference
    225/40-18-----3.5in----12.5in---25.1in-----78.8in---------804-------0.0%
    235/40-18-----3.7in----12.7in---25.4in-----79.8in---------794-------1.3%
    there is only a 1.3% difference between the two.
    but there is a huge difference in price - as in half (or more) the price of the 225s. the 235s r a more common size here.
    i guess my question is that can we fit 235 tyres on the 7Jx18 rims?
    MY17 Superb 162TSI, Business Grey, Tech+Comfort Pack, APR ECU+TCU Stg 1, SLA, Rieger Splitter + Side Skirts, Eibach Pro-Kit Springs, Hardrace Swaybar, TPMS
  3. #23
    Jul 2010
    Quote Originally Posted by dArK5HaD0w View Post
    damn it......i just found out....short answer is no for the octavia rs rims
    Rim width--Min tyre width-Ideal tyre width-Max tyre width
    5.0 inches--155 mm--------165 or 175 mm--185 mm
    5.5 inches--165 mm--------175 or 185 mm--195 mm
    6.0 inches--175 mm--------185 or 195 mm--205 mm
    6.5 inches--185 mm--------195 or 205 mm--215 mm
    7.0 inches--195 mm--------205 or 215 mm--225 mm
    7.5 inches--205 mm--------215 or 225 mm--235 mm
    8.0 inches--215 mm--------225 or 235 mm--245 mm
    8.5 inches--225 mm--------235 or 245 mm--255 mm
    9,0 inches--235 mm--------245 or 255 mm--265 mm
    doh doh doh
    guess if i want cheaper tyres, i'll need new rims first!!!
  4. #24
    Erskineville, NSW
    Quote Originally Posted by drew-8888 View Post
    Only that I'd look on ebay for tyres+wheels that have been removed for a 17" upgrade. You'll get 4 near new tyres on rims for <$600
    I think the RS has 7.5" rims. Doesn't matter though as 235/40x18 is 8" rim minimum for most makes
    edit: That table is a fair indication but sidewall height makes a big difference. The taller the sidewall, the more "gimme" in rim size/range
  5. #25
    Jul 2010
    according to the skoda oz brochure, the RS comes fitted with 7" wide rims.
  6. #26
    Erskineville, NSW
    According to my Skoda Oz brochure - 7.5"x18 but Skoda seem to change the numbersat a whim. Probably best you look at the number casting on the inside of the wheel web/spoke.
    7" is generally too narrow for a 225/40x18 (but would be OK for 225/45x1.
  7. #27
    Jul 2010
    what the?!?!
    according to the brochure from the skoda oz website (published date: Aug 2009), "Wheels".......
    7" is generally too narrow for a 225/40x18 (but would be OK for 225/45x18.)
    "225" is tyre width in millimeters. it doesn't matter if its a '40' profile or '45' profile, if its 225, then it will b the same for both sizes.
    hence a 7" rim can't be narrow for one, but not the other.
    what would change (between 225/40/18 & 225/45/18.) is the tyre's sidewall thickness, and hence the rolling diameter, & the speedo, & the revs per mile etc etc.
  8. #28
    Apr 2010
    Melbourne, Victoria
    what would change (between 225/40/18 & 225/45/18.) is the tyre's sidewall thickness, and hence the rolling diameter...
    I think you really meant the sidewall height (not thickness).
  9. #29
    Jul 2010
    Quote Originally Posted by pwcar View Post
    hehehheheh......that would b correct - the sidewall height
  10. #30
    Jan 2010
    Bathurst, NSW
    Vehicle Categories - Bob Jane T-Marts
    Bob Jane's site might be worth a look. Has a tool to tell if a tyre will fit your car or not.
    This might cause some conjecture, but I had some Maxxis MA-V1's on my Fiesta Zetec (also a strange sized wheel for a small car). I bought them because Wheels or Motor did tyre testing and the Maxxis' always come 2nd or third and were always best value for money. Not only were they reasonably priced, but they were just as good, if not better than what they replaced. I got about 30000k's of mixed driving out of them without a rotation (I know, I'm a bad man for not managing my tyre wear). The only thing I noticed were they were slightly noisier than what they replaced (it wasn't the most refined car anyway).
