Results 1 to 10 of 16
Thread: Skoda Octavia vRS TDI CR + OBD II bluetooth scanner + Galaxy Tab + Torque Pro
    Bowral, NSW
    Pretty much the topic header.
    This is the readout I get after an average drive to the girlfriends, the car idling for 15min outside her front gate, then the drive home.
    I've modified all the gauges so they start just under the lowest setting, and finish just over the highest setting achievable. (Usually max boost + over 4,500rpm)
    I picked up the BT unit off eBay for around $15 shipped. Took about a week to get here, from China.
    Torque Pro is around AU$4.85. Worth it, over the free version.
    2012 Octavia vRS TDI. Darkside big turbo, 3bar tune, other stuff. 200kW/650Nm.
    1990 Mk1 Cabrio. 1.9 IDI w/ 18PSI.
    1985 Mazda T3500 adventuremobile. 1973 Superbug. 1972 Volvo 144 in poo-brown.
    Not including hers...
    Jan 2012
    nice!!
    i wish i could get all that data on the satnav. i dont like not having a boost gauge
    Mar 2010
    Witness Protection
    I'd love to see a photo of your set up.
    Also, I hope you can answer something that has had me puzzled for a long time - what is it with diesel drivers and leaving their cars idling for ages? What's the reasoning behind it?
    Bowral, NSW
    Quote Originally Posted by hooba View Post
    Hahah, sure. I'll take some pics tomorrow... When its not 1.5^C outside.
    The idea behind the idling can be easiest explained by reading up the phenomena behind the 'turbo timer.'
    See: Turbo timer - Wikipedia, the free encyclopedia
    Basically... You sit there and let it idle instead.
    Also - Diesels use less fuel at idle.
    E.G. A 2008(?) Astra 1.8 (or something) uses 1.2L/hr at idle, my vRS uses 0.4-0.5.
    When it uses this little, why bother turning it off if you're moving off again in 5min??
    Keep the sat nav, air con, heater, etc running! :p
    And plus. They sound good, don't they? XD
    Oct 2010
    Pity the AFR is out so much, would be revving and smoking its guts out with that AFR
    I noticed this the other day when I set my Galaxy back up with Torque.
    Golf GT Sport TDI
    Bowral, NSW
    Quote Originally Posted by jazd View Post
    Is it?
    I honestly have no idea about these things.
    Will learn one day... Just one of those "Can I really be bothered?" things.
    Kinda like the i7 processor.
    Jul 2010
    so how does it work exactly?
    how does the obd 2 bluetooth scanner communicate with the car directly? is there some sort of piggyback (bluetooth transmitter) u place on the car's obd port.
    MY17 Superb 162TSI, Business Grey, Tech+Comfort Pack, APR ECU+TCU Stg 1, SLA, Rieger Splitter + Side Skirts, Eibach Pro-Kit Springs, Hardrace Swaybar, TPMS
    Erskineville, NSW
    Quote Originally Posted by Mysticality View Post
    Actually, they use less fuel when turned off Idling for more than about 30s uses more fuel than switching off/on. 60s is the break-even point if you take into account battery & starter motor wear.
    Unless you've been thrashing the engine beforehand, it is not necessary to idle-down the turbo. The Skodas are fitted with a post-shutdown water pump that circulates water through the cooling circuit of the turbo & a similar pump for the oil supply. So unless you've been doing hotlaps of the local area, idle-down is redundant. Turbo-Timers are very 1990s.
    Prolonged idling in any turbo-diesel is also an outdated idea. All it does is use fuel, pollute the air & wear out the engine. It causes a thing called diesel plugging which is a build-up of carbon around the rings & other components & also wetstacking (buildup of liquid soot in the exhaust circuit).
    Basically, a diesel is designed to operate under load. Idle doesn't load them enough. If you need to sit for prolonged periods then you need to bring the RPM up to 1200 to load the rings, increase EGTs, increase fuel burn efficiency & reduce water vapour.
    My info is based on what my engine vendors (Detroit Diesel/MTU) were telling me when I was buying stationary engines off them between 2002-2007. We were having issues with the operators wanting to idle the engines for excessive periods (causing plugging & wetstacking) & the vendors wanted to put in an idle routine in the ECU that would punt the engines to 1200 if they idled for more than 5 minutes.
    Sorry for the lecture but there are a lot of outdated practices out there in diesel-land.
    Jan 2012
    turbo timers are useless IMO
    if you dont thrash your car all the way to your parking spot, why idle it down? the turbo is water cooled and oil lubricated. it doesnt need to be 'cooled down'
    Bowral, NSW
    Here are some pics of how I've run the wiring.
    [img[http://a3.sphotos.ak.fbcdn.net/hphotos-ak-ash3/s720x720/537735_10150888585548117_785693116_9837674_6265342 49_n.jpg[/img]
    Strongly considering getting the dealership to wire up a couple of aux. power points to a bracket that sits next to the cubby hole on the drivers side, next to the door.
    Means I can run the tablet AND charge the phone at the same time.
    Or the mate's phone, that I swear never sees a charger, except when its in my car.
