Results 1 to 5 of 5
Thread: Skoda Octavia RS MY11 - New intake manifold, carbon clean, diy walnut blaster 1of2
    Mar 2016
    5044 SA
    Disclaimer: This was my experience, make sure you do enough research that you are confident to attempt this. I have written this to help those who are researching or are unsure if they have the skills to do this. I take no responsibility if you damage your car.
    Also applies to VW GTI MK 6 and Audi 2.0T (not sure of the models)
    Car history -160000 km - owned since new
    Major faults - clock spring ribbon broke - diy fix with new genuine part sourced via ebay from EU. Timing chain tensioner failed 120000km Feb 16, chain stretched and fixed by solitaire partly paid by Skoda Aust cost to me $1800. Intake manifold failure April 2018 - P2015 code
    Symptoms
    It misfired at low rpm and fuel economy was up and power was down. It got worse and worse until the engine light came on.The manifold actually failed at the flap shaft and popped out. This caused the car to have major misfires and run very rough, but it never stalled. I fixed it temporarily by pushing the shaft back in and only driving the car under 3k rpm.
    I got a quote to have the manifold replaced and walnut blast carbon clean for $1800 from an independent, needless to say, I decided to diy.
    This writeup isn't a how to do, others have done much better jobs see vids and forums threads below, it is more about outlining some of the things that i struggled with and took me a long time to do and I hope by sharing my experience you can save a lot of time.
    I used youtube for the overall process, these videos in particular
    Humble Mechanic intake removal
    https://www.youtube.com/watch?v=c7c35MJq5e0&t=236s&index=3&list=PLuSmZRMiA RcAtRqA-5K1PdEf2sNTml32H
    Edge Motors intake removal
    https://www.youtube.com/watch?v=Ugh9vPz2Zd8&t=1019s&index=8&list=PLuSmZRMi ARcAtRqA-5K1PdEf2sNTml32H
    Also used these threads for info http://www.vwgolf.net.au/showthread.php?13989-Carbon-buildup-on-MK6-GTI-engine-2.0T-TSI
    http://forums.vwvortex.com/showthread.php?5200508-CCTA-and-intake-manifold-flap-position-Code-P2015/page2
    Parts sourcing
    I got parts from the following places
    From qeautoparts1 ebay US
    Intake manifold Volkswagen Audi A3 TT Jetta Beetle Eos Intake Manifold Genuine 06J133201BH. $240 AUD delivered
    Oemvwparts.com Czech Republic
    Fuel injector seals, 06J998907D
    Manifold breather hose - connecting hose 06H133583F
    Air filter element 1K0129620D
    RADUM VIC Aust
    Walnut shells 20kg fine
    Bunnings
    Ozito 23kg Portable Sandblaster
    Ozito Air nozzles
    Ozito 1250W 12L Stainless Wet and Dry Vacuum
    Repco
    Carby cleaner $7
    runautoparts.com.au
    Coolant expansion tank V10-0433 and new wipers
    Tools and 110psi max compressor - borrowed
    I also own the Ross Tech VCDS Micro Can scan tool which I bought to fix recode the clockspring.
    Intake removal and replacement
    Pretty simple process watch the above vids at least once.
    10mm triple square (M10)
    The Edge motors video has a different angle so you can see the 10mm triple square removal and access better than the Humble mech video. I struggled accessing the 10mm triple square, you definitely need a ⅜ socket with extension bars and uni joints. The socket kit i borrowed was quite worn which made this bolt removal harder because there was a bit of play in every joint and connection. If I do it again, I would buy a new socket kit. I also removed the throttle body off the manifold before I took the 10mm triple bolt out, it made access easier.
    One thing I didn’t do which I probably should have was to completely take off the charge pipe, I couldn’t be bothered jacking the car to get to the bolt underneath. But it is something that both vids referenced above do and would definitely make it easier to get to the triple square.
    Continued in Part 2
    Attached Thumbnails Attached Thumbnails Skoda Octavia RS MY11 - New intake manifold, carbon clean, diy walnut blaster 1of2-blow-gun-set-jpg   Skoda Octavia RS MY11 - New intake manifold, carbon clean, diy walnut blaster 1of2-img_20180617_123552431-jpg
    Skoda Octavia RS MY11 - New intake manifold, carbon clean, diy walnut blaster 1of2-blaster-nozzle-modified-gun-jpg   Skoda Octavia RS MY11 - New intake manifold, carbon clean, diy walnut blaster 1of2-blaster-nozzle-mod-jpg
    Skoda Octavia RS MY11 - New intake manifold, carbon clean, diy walnut blaster 1of2-blaster-nozzle-mod-2-jpg   Skoda Octavia RS MY11 - New intake manifold, carbon clean, diy walnut blaster 1of2-injectors-carby-cleaner-jpg
    Skoda Octavia RS MY11 - New intake manifold, carbon clean, diy walnut blaster 1of2-vacuum-cleaner-attachment-hole-blaster-jpg   Skoda Octavia RS MY11 - New intake manifold, carbon clean, diy walnut blaster 1of2-walnut-blaster-jpg
    Skoda Octavia RS MY11 - New intake manifold, carbon clean, diy walnut blaster 1of2-walnut-shells-after-finished-blasting-vacuum-barrel-jpg
    Mar 2016
    5044 SA
    Part 2
    Injector removal and new seals
    All four injectors came out with the manifold. They needed a lot of effort to remove them from the manifold. Once out I sat them in a jar of carby cleaner for a week and gave them a polish with a clean rag
    Installing new injector seals
    I tried to clean the injector port with a small plastic brush, the carby cleaner and a rag It sort of worked but using the right tools would help.
    I did not have the injector seal tool so I did it with the old pen trick -not recommended. I did get them on in the end, but I struggled with compressing the seal back in the groove. It did feel like the seal compressed as I put the injectors back in the head. And it is so far so good. So for peace of mind, try and borrow or buy the proper kit for this job.
    Carbon clean and DIY blaster
    Make sure the valves are closed on the intake port you are looking to clean - it is very obvious which ones are open and closed. Look at my before videos to see the differences in open vs closed.
    I used the walnut blast process because it looked easier and cleaner than spending hours scrubbing with carby cleaner. I had to mod the ozito blaster nozzle, I used an air gun nozzle and glued it in with a metal 2 part glue.
    Skoda Octavia RS MY11 - New intake manifold, carbon clean, diy walnut blaster 1of2-blaster-nozzle-mod-2-jpgSkoda Octavia RS MY11 - New intake manifold, carbon clean, diy walnut blaster 1of2-blaster-nozzle-mod-jpgSkoda Octavia RS MY11 - New intake manifold, carbon clean, diy walnut blaster 1of2-blow-gun-set-jpgSkoda Octavia RS MY11 - New intake manifold, carbon clean, diy walnut blaster 1of2-blaster-nozzle-modified-gun-jpg
    This worked really well, the hardest part of the carbon clean process was directing the abrasive to the area that needs it. The way I did it with the vacuum cleaner attachment, meant that i was flying blind. Later I thought that it might be good to use a clear pipe, that way you could see what you are doing.
    Skoda Octavia RS MY11 - New intake manifold, carbon clean, diy walnut blaster 1of2-vacuum-cleaner-attachment-hole-blaster-jpgSkoda Octavia RS MY11 - New intake manifold, carbon clean, diy walnut blaster 1of2-img_20180617_123552431-jpg
    This is the blaster with walnuts in it and the diy blaster nozzle connected
    In the blaster video, I was just trying to show how quick it is to clean using this process - a lot of the carbon is gone after a short time using the blaster.
    I also used a pick and small flathead screwdriver to scrape down behind the valve stem and at the back of the port. Then it was easy enough to just vacuum out the carbon gunk.
    I didn’t really keep track of the time doing the carbon cleaning, but I think I probably spent about 15 mins per port. You can see from the vids my ports were not perfect, especially at the top of the intake port as I couldn’t get the blaster nozzle to point up there. But much improved over what they were like before the clean.
    Intake runners clean
    I soaked these in carby cleaner for about a week (only because I had to wait for the walnuts to arrive) and the carbon just wiped off with a rag.
    Turning the motor
    I used a 24mm socket on the crank bolt, turned it clockwise a small amount which moved the valves I needed.
    Intake reinstall
    Pretty much just the reverse of removal. I did attach everything that I could before putting it back on the car. This included - throttle body, fuel line and the bracket that goes from manifold to block. I attached the bracket to the manifold loosely and very carefully guided it in to place as I couldn’t really see how I could get the bracket in place after putting the manifold on without losing my mind. Again I struggled with the triple square, I put the bolt in with the tips of my fingers and wound it as far as possible using my fingers then used the ⅜ socket extensions and unijoint. Not fun.
    All the manifold bolts and nuts went on no problem. I bought the additional manifold breather hose for the extra vacuum that is for the new solenoid design. I routed this to sit on top of the motor between coils 2 and 3.
    Fuel pump prime
    I just turned the car on and off about 5 times before attempting to start it. It started quickly, I cleared the faults and took it for a drive, fixed. BUT the engine light came on with new fault code about fuel flap runner. I had forgotten to plug in the manifold solenoid plug - replugged and cleared code and another drive.
    Results
    Big difference in fuel economy, also now there are no misfires or stutters between 1-2k rpm, it’s just smooth. Also massive difference in power and responsiveness - the carbon buildup happens so gradually that you don’t notice how much it impacts over time.
    Random thoughts
    Having the correct clamp pliers, good lighting, strong magnetic pickup tool, lots of patience, will help.
    Work out the method for removing the electrical plugs - make sure you understand which part to press because some of these you need to do blind.
    I also changed the air filter and the coolant expansion tank (the plastic of the old one was heavily crazed). Part numbers are listed above.
    This is the walnuts and carbon in the vacuum barrel. I only used about 2kg of walnuts of the 20kg bag.
    I am happy that I did it and it worked! Also saved a ton of money. I hope this helps anyone who is on the fence over doing this themselves.
    Videos I took
    Intake valves at 160000 kms before
    https://youtu.be/NzIRe6_1cpY
    Walnut blaster process
    https://youtu.be/MjERtmx_WBs
    Cylinder 2 Before cleaning, 3 and 4 after cleaning
    https://youtu.be/G1OWPUsnGyg
    Old intake manifold, oil buildup and dirty injectors
    YouTube
    Oct 2014
    Awesome work on the DIY mate!!!
    Peregian Beach
    So did you notice any difference in driving the car and/or fuel consumption changes etc
    Epic DIY !
    RS
    R
