Hey Team,
I Need some help.
I own a 2014 Skoda Octavia RS the 147TSI model and it has done 80,000k's perfect car but in 4 weeks its turned into a real garage queen.
Firstly the Car started running really rough at idle when cold almost as if it is running to lean.
I took it into the Dealer and they said oh its a computer issue and upgraded the firmware, still no luck doing the same thing.
Took it back and they said yep must be a spark plug issue, ok made sense fouled plugs do that, they replaced them still no luck.
Then on the weekend when driving it all of a sudden started to feel like the clutches were slipping really weird like either the engine was not delivering the required tourqe or the clutches were stuffed, but it seemed at low revs the car would shudder but at higher revs it performed perfectly. i am waiting on a call back from the dealer.
Any ideas or suggestions?, Engine issue or Clutch?
Scott
