Page 18 of 45 FirstFirst ... 8161718192028 ... LastLast
Results 171 to 180 of 445
Thread: Skoda Modifications
  1. #171
    Jun 2013
    United Kingdom
    Posted this elsewhere, but will post here too. If anyone want's any advice/info about any of the mods i'm always happy to help.
    Last Car.
    MY07 Octavia vRS 2.0 TFSi Race Blue Hatchback - Bought new Mar 2007 REVO Stage 2 (270bhp dyno dynamics proven), Milltek Full TBE, EVOMS CAI, APR Fuel Pump, Neuspeed Turbo Discharge, Neuspeed Hi-Flow Intercooler pipe, BSH Stage 2 Catch Can, Modified OEM Engine Cover for EVOMS, Audi S3 All Alloy Intercooler, VF Engineering Engine, Transmission and Dog Bone Mounts, R32 Brakes with J-Hooked discs, Audi S3 Lower Control Arms, Eibach front and rear ARB, Koni FSD Suspension and Eibach springs, OEM RNS 510 retro fitted, OEM Sun Blinds, Catvision Interior lighting mod, Fiscon Basic Plus bluetooth with OEM Microphone, Drivers seat storage box, LED interior lighting, LED Number plate lights, Carbon Fibre wrapped interior and parts of Exterior, LED DRL retrofitted, 55w Xenon HID retrofitted, Cruise Control retrofitted. L&K LED Door handle lights Retro fitted. Relocated DV to K04 position.
    Current car
    MY2011 vRS 2.0TSi Estate, 6spd DSG, Anthracite Grey - Bought new June 2011 with every factory fit optional extra except RNS510 (retrofitted by myself on day of delivery). Revo Stage 1, ITG Panel Filter, Neuspeed Turbo Discharge Pipe, Neuspeed Hi-Flow Intercooler Pipe, OEM Audi S3 all alloy intercooler, VF Engineering Engine, Transmission and Lower Mounts, Audi S3 Lower Control Arms, Eibach Front and Rear ARB's, OSIR Aluminium DSG Paddles, RNS510 with latest firmware and maps. Blue LED Interior lights and White LED boot lights, Catvison Interior Light and OEM interior light moved to rear, Full OEM Skoda Sun blinds, Full interior soundproofing (floor, doors, side panels and wheel arches) L&K LED Door handle lights Retro fitted. Audi Jacking point mounts, 345mm Front Brakes with J-Hooked discs. Colour coded front grille surround. Front bumper lower lip Spolier, Fully detailed and protected with Swissvax, FinishKare and Gtechniq products.
    Here is a pic of the last and current car
  2. #172
    Jul 2013
    Caulfield, VIC
    Hey mate,
    Got a set of these sitting at home ready to go. Did you wire them in to the red door lights? If so, how did you physical wire them, which wires to which wires.
    Cheers,
  3. #173
    Bowral, NSW
    Quote Originally Posted by MountainBikeMike View Post
    Hey mate,
    Cheers,
    Hey!
    I have these as well.
    The red door lights have two wires, as do the projector lights.
    If you have them set to the wrong polarity - they just won't light up, so you swap the wires over!
    -Cheers
    2012 Octavia vRS TDI. Darkside big turbo, 3bar tune, other stuff. 200kW/650Nm.
    1990 Mk1 Cabrio. 1.9 IDI w/ 18PSI.
    1985 Mazda T3500 adventuremobile. 1973 Superbug. 1972 Volvo 144 in poo-brown.
    Not including hers...
  4. #174
    Jul 2013
    Caulfield, VIC
    Quote Originally Posted by Mysticality View Post
    Hey!
    -Cheers
    Thanks, love em.
    Gday to another scouts member as well. I was in it for 7 years but I stopped about 5 years ago as mountainbiking took up all my spare timing with at least 12 races a year etc..
  5. #175
    Bowral, NSW
    Thanks, love em.
    No worries!!
    I'm still a member, but I don't have the time anymore... Haven't been in awhile.
  6. #176
    I think I've finally stopped the dreaded glovebox squeak that has been plagueing me on and off for a while now. Have only been able to quiet it on a temporary basis with tightening screws or using silicon sprays.
    I used some pieces of non-slip mat (the perforated stuff you get for about $3 from BigW or Supercheap or heaps of other places. I cut them into about 50c piece sized pieces and then removed the screws and put the pieces of mat in between the glovebox and dash plastic at the mount points, then put the screws pack through the hole and through the middle of the non-slip mat piece. I only had to do the two screw points at the dash end where you remove the plastic cover.
    The result is complete silence from that side of the car, something I've not experienced since a few months into ownership.
    I can take some pictures if anyone wants more detail but its pretty self-explainatory.
  7. #177
    Jul 2013
    Caulfield, VIC
    www.TheRapidWrench.Melbourne
    The convenient, professional and affordable mobile bicycle mechanic that comes to you!
    My RS build thread
  8. #178
    Continuing on my quest to rid the world (or at least my Octy) of filament globes...
    I bought these ones. They are available in white, red and yellow (and blue and green?)
    They appear very well built and I think worth spending a little more than some of the cheaper looking constructions floating around.
    They have a lensed 7w Cree led and 12 SMD leds around the shaft so give off a very good projected light as well as filling the OEM housing in the same way as a filament globe.
    Installed one white set as reverse lights and one set to test of reds in my stop lamps (right side). I had previously tried some white LEDs in the tails but they dont work well as they are brighter than the filament globes they replace so look pink through the red plastic.
    The red ones actually look red and are slightly brighter than the stock globes. More importantly they light up full brightness instantly on applying the middle pedal.
    The white globes through the clear housing for reverse are much brighter than the stock halogens, plus are crystal white rather than halogen white, so also look nicer to boot.
    I took some photos on the phone but they are absolutely terrible, low light is never a forte of camera phones....
    But I think the upgrade is worth it, might have to try and take some pics with the SLR to post.
    I am going to get another set of reds to fully replace the stop lamps (there are two globes in each housing) as well as yellows for turn signals as the ones I have now could be a little brighter in daylight, they dont have a projector lens in them.
  9. #179
    Jun 2011
    Darwin, NT
    How about CAN BUS?
    Happy Days
  10. #180
    Re: Skoda Modifications
    Quote Originally Posted by joel0407 View Post
    How about CAN BUS?
    Happy Days
    Yep, I have a canbus
    I've only driven for about half an hour so far but no bulb out errors yet....fingers crossed.
    Sent from my HTC One using Tapatalk 2
