Page 37 of 45 FirstFirst ... 273536373839 ... LastLast
Results 361 to 370 of 445
Thread: Skoda Modifications
  1. #361
    Apr 2009
    Northern Tasmania
    I've had a Bluefin in my 2008 TDI for a few years and just put a Racechips Response Control ($299 with free overnight delivery) throttle control in.
    » Throttle TuningRacechip
    Skoda Modifications-racechip-jpg
    Simple install, just unplug the throttle pedal connector and plug the Racechip between the two. Route the cable discretely and stick the control somewhere you would like it.
    I don't know if it does anything other than just change the 'curve' of how the accelerator is applied, but it's quite dramatic at the extreme settings. Anything from glacial response and extremely slow acceleration in Eco2 mode right through half a dozen modes to very zippy in Sport2 mode. Around mid level and a couple up would be most used. Only had one short drive so far, but combined with the Bluefin and my Haldex sport controller set on Race is a lot of zip on dirt roads.
    I was tempted to get one called EDrive Advance 4, but wasn't sure of the quality of that - it seems a bit more versatile - and about $100 cheaper. There's some even cheaper ones around of dubious quality that supposedly can cause trouble with the car.
    E-Drive 4 Advance Throttle Controller – Sprint Booster – Blitz Style
    2008 Skoda Octavia Elegance TDI 4x4 wagon
    Bluefin 132Kw/385Nm, Racechips Response Control, Haldex Performance controller, H&R anti roll bars, Koni FSD shocks, SuperPro control arms & ball joints, subframe & gearshift mods, Full Dynamat interior, Polk Audio sound, Columbus, Bluetooth, MDI, parking sensors, camera. BBS SR 18x8" w/ 225/40xR18. 3M Crystalline tint.
  2. #362
    May 2012
    Quote Originally Posted by lunchboxGTI View Post
    I got a race chip ultimate installed today. Will update tomorrow on how it gos during the day.
    So it's been a week with the chip and overall it's good to go.
    So I paid $1000 all up installed you could probably get it cheaper as the Aus site has them for $699 and you could put in yourself but mine was through the dealer so I can take it back if there are issues plus they reset the computer and emission controls to match and it's set up for my indavidual car.
    Power is 213kw 420nm. I know some direct port tunes are getting more but I can pull this out in 30min and take in for warranty work if needed.
    The app works fine. Though there's not much to it. You can choice between 3 modes. You can set a timer so it only kicks in after a pre set time.
    Driving wise you notice the difference. It really works well in sport or when you flick to manual mode. It's defiantly a big boost.
    However when on normal it can be a bit funny only because it will wants to change up quick and if you decide to stab it the power increase is a little much for it. you will get the extra kick but unless you push the pedal to the floor it will Change up and feel a littl abrupt. Having said that you can still drive around normally without an issue and as I'm sure most of you would do anyway flip it to manual or sport to have some fun.
    The tip I would give is that to use the app you need to scan the barcode of the unit before you plug it in. My dealer hide it away then told me the barcode was on the packet. Coincidently the bar code came up as a seat Leon. So I have to pull some things back off to get the could. I then placed the unit in a better spot.
    MY16 Candy white Octavia VRS Wagon, sunroof, 19" black pack, tech pack, comfort pack, auto tail gate
    MY12.5 Polo 6R GTI
  3. #363
    Aug 2016
    Salisbury, Queensland
    So lunchbox, are you still happy with the Race Chip? I'm looking at an apr but if this thing does 3/4 of the benefit for 1/2 the price.......................
  4. #364
    Bowral, NSW
    Quote Originally Posted by zippythelown View Post
    Be very very careful with plug-in chips, as they trick the ECU into giving the engine different timing and fuel levels, by faking the temperature and sensor readings.
    The benefit of a proper tune is that the ECU knows exactly whats going on and can still pull it back into a more "safe mode" (read: NOT limp mode) if it has to, whereas with a chip the ECU is thinking to itself "I've done all I can and its still not right! Whats going on?!"
    2012 Octavia vRS TDI. Darkside big turbo, 3bar tune, other stuff. 200kW/650Nm.
    1990 Mk1 Cabrio. 1.9 IDI w/ 18PSI.
    1985 Mazda T3500 adventuremobile. 1973 Superbug. 1972 Volvo 144 in poo-brown.
    Not including hers...
  5. #365
    Jun 2011
    Darwin, NT
    Quote Originally Posted by Mysticality View Post
    Plus one. So many people go this way without really knowing the risks. It might still run for thousands of KM and not have a problem but still be shortening the life of the motor considerably.
    Get a proper tune or don't tune at all.
    Happy days
  6. #366
    May 2012
    Not so. A lot of the time when the Ecu is tuned it removes a lot of the safe modes that are in the factory tune And adds it's own higher limits. There are pros and cons for both. I've used both and had no dramas. This piggyback dosnt trick temperature just to increase fuel like some did in the early days. There a lot more advance now. Your incorrect about the different timing as a chip only effects fuel and air. Compared to a ecu tune that can effect all 3. That's why a chip has less improvement. It really comes down to the computing power. As long as it's 64 bit there should be no dramas on a modern vehicle. The computer is nearly as big as the original ecu.
    Still liking the tune. I havnt changed suspension or wheels so it can be a little overpowering. The extra power from an apr tune would be a waste without some other tweaks but still an option.
    Every ones going to have there own opinion. I've tuned a lot of Subarus with tatrix cables that replace the tune or Cobb intercept boxes. It's all about how it's done. Most of these tunes are still on the conservative side.
    MY12.5 Polo 6R GTI
  7. #367
    Jun 2016
    Anyone had much to do with Revo Technik?
    There is a dealer on the sunny coast, anyone used them?
    Any good?
    Will be looking at Stage 1 next year (mid)
    Skoda RS 230
    "The Grey Ghost"
    SG-TP-AB RS230 - Timeline
  8. #368
    Dec 2016
    Brisbane Qld
    Quote Originally Posted by HPRS230 View Post
    Any good?
    Where abouts? I'm on the sunny coast today for work....
    MY16 Octavia VRS Wagon, DSG, Race blue, Tech pack, Comfort pack, Black Pack, 19's, Sunroof, Electric Tailgate
    Airbox mod, VW Racing Filter, TMD, Elbow, Ramair Pipe, GFB DV+, VCDS mods, Superpro adjustable rear sway bar, Superpro end links, Whiteline front sway bar links, Whiteline LCA bush Kit, Bilstein B14 coilovers, HPA dog bone mount & arm, 42DD oil catch can, Burger wheel spacers, CTS downpipe 200 cel cat, 2,5" exhaust , twin out. Super Skoda eyelids & front splitter, Tuned by BPS 228kw atw, Dsg tune,
  9. #369
    Jun 2016
    Quote Originally Posted by ferret vrs View Post
    Euro Car Upgrades Pty Ltd (Premises 1)
    14 Sunshine Cove Way
    Maroochydore
    Queensland
    Suss it out Mate, Cheers
  10. #370
    Bowral, NSW
    Any good?
    I had a Stage 2 on my derv; did the job.
