Page 31 of 45 FirstFirst ... 21293031323341 ... LastLast
Results 301 to 310 of 445
Thread: Skoda Modifications
  1. #301
    Jun 2013
    Gold Coast
    Just wondering if anyone has gone down the exhaust route on their 162TSI RS yet?
    keen to hear your thoughts and results.
    Thanks
  2. #302
    Apr 2008
    Western Sydney
    Quote Originally Posted by godzilla_110TDI View Post
    Thanks
    I think Milltek is one of the few out there. There's sound clips and whatnot on the Briskoda forum. One aussie bloke (doesn't post here though) put one on and mentioned the note doesn't much change from stock apart from the extra dsg pops and farts you now get. Though i think you'll get a CEL with the exhaust unless you get a tune. I plan on doing just the downpipe initially and if there isn't much extra noise i may get a custom catback.
  3. #303
    Jun 2013
    Gold Coast
    Why would an exhaust throw up a CEL?
  4. #304
    Apr 2008
    Western Sydney
    I'm no expert but its got to do with the O2 sensor on the downpipe. Even Milltek recommend a tune with the exhaust.
  5. #305
    Oct 2010
    Down pipe will slightly move the o2 sensor in relation to stock position. This will give different readings (as distance from exhaust is taken into account in the calculations). Different readings to expected = CEL
    2014 Skoda Ambition Plus 103TSI candy white wagon, 6sp Manual, Tech pack, Panoramic Sunroof, 18's, Colour Maxidot, Comfort BT
    Ordered 07 May 14 (Wk 15), Built Wk 37, Loaded 27/9 (wk 39), Docked 12/11 (wk 46), DELIVERED! 12/12 (end of wk 50 - 7 months + 1 week).
  6. #306
    Apr 2009
    Northern Tasmania
    Just put a Haldex sport controller in my 4x4 Octavia. This gives the Gen 2 Haldex in my car switchable (by a remote) Stock, Sport & Race mode's for the balance of drive through the Haldex drive to the rear wheels. In Stock mode the balance is mostly to drive the front wheels (along the lines of 98/2 %) only putting drive through to the back when they slip (I've never felt them slip so it must be quick). Sport mode puts more drive to the rear before it slips (so pretty much all the time). Race mode does that too, but quicker.
    Just had a quick blat along a windy tarmac and dirt road and you can feel it, particularly fun on the dirt.
    Haldex Performance Controllers | HPA Motorsports, Inc.
    Bit of a gamble at $1480 (and that's a special price at the moment. Normally it's $1600!), since it's produced in Canada and they don't have TDI's in Northern America so I wasn't sure it would suit mine.
    Goes on fairly easily except getting the electrical connectors off the Haldex is tricky. You need to route a cable through to the boot for the remote control box which has to be inside the car.
    I have a set of H&R anti roll bars and have the rear one on (noticeable difference). Also Superpro lower control arms with anti lift bushings (was going to be just a Whiteline anti lift bush kit - now for sale) and Koni FSD shocks to go on soon.
    2008 Skoda Octavia Elegance TDI 4x4 wagon
    Bluefin 132Kw/385Nm, Racechips Response Control, Haldex Performance controller, H&R anti roll bars, Koni FSD shocks, SuperPro control arms & ball joints, subframe & gearshift mods, Full Dynamat interior, Polk Audio sound, Columbus, Bluetooth, MDI, parking sensors, camera. BBS SR 18x8" w/ 225/40xR18. 3M Crystalline tint.
  7. #307
    Melbourne, Vic
    Quote Originally Posted by readerr0r View Post
    When tweaking a clients superb with a similar system, I found you have to tell the park sensors control module that a reserve camera is present. At the time the tickbox didn't exist in VCDS on skodas, I had to copy the raw hex code from a VCDS screenshot the client luckily happened to have from a VW module, but I think its in VCDS 12 now...
    Edit: Here's a shot of the working code. Remember some settings might be telling it to expect a superb sized car.
    Looking at the coding I just did similar on my RS, BUT you only need to add @ byte 0, bit 6 in module 10 with the long coding helper. If not immediately there then use Lcode 2 and do it manually. You also need @byte 3, bit 6 in module 37. Do the same with lcode 2 if not available as a check box.
    Works perfectly.
    I took Kamold's suggestion and actually powered from the rear wiper +12V and used a relay, with the rear led as the switching current. Then at the front I used the same switching current and powered the RGBS converter with another relay from the RNS 510 permanent +12V.
    The Camera I got has a particular video cable with a current wire in parallel so I dont have to run 2 cables to front for the second switching wire for the front relay
    2001 - A4 B6 1.8T Sedan Manual - (sold @ 254,000km)
    2008 - A3 8P 1.9tdi Sportback Manual - (sold 90,000kms)
    2013 - Octavia RS wagon - 1z - Race Blue - TDI - 6M - Leather - MDI - Whispbar S44W - LED interior kit - RVC forward?/retrofit - Mk3 gear shifter
    2021 - Q3 S-Line wagon - F3 - Daytona Grey - Westfalia towbar - no other options available.
  8. #308
    Apr 2009
    Northern Tasmania
    I had a Whiteline WALK and lower control arm front bush I was going to install, but then got SuperPro alloy lower control arms instead. Here's some pics comparing standard, Whiteline (gold) and SuperPro. The Whiteline comes with optional even harder inserts for the bush suitable for track use.
    Skoda Modifications-2015-06-27-12-07-33-jpg
    Skoda Modifications-2015-06-27-12-08-08-jpg
    Skoda Modifications-2015-06-27-12-08-26-jpg
  9. #309
    Apr 2009
    Northern Tasmania
    Here's the SuperPro arms
    Skoda Modifications-superpro1-jpg
    Skoda Modifications-superpro2-jpg
  10. #310
    Jan 2015
    Just got a APR Stage 1 flash done at Prestige Auto Works on my MY15 VRS. Massive difference. Thumbs up to the fellas there the service was very good.
