Newer ecus are encrypted and can't be flashed directly via odbII before they are unlocked.
Sent from my HTC One using Tapatalk
www.TheRapidWrench.Melbourne
The convenient, professional and affordable mobile bicycle mechanic that comes to you!
My RS build thread
Grrrr!!
I was hoping to be the first tuned diesel. :p
Where'd you get it done?
Definitely update with info!... And fuel economy!![]()
2012 Octavia vRS TDI. Darkside big turbo, 3bar tune, other stuff. 200kW/650Nm.
1990 Mk1 Cabrio. 1.9 IDI w/ 18PSI.
1985 Mazda T3500 adventuremobile. 1973 Superbug. 1972 Volvo 144 in poo-brown.
Not including hers...
My RS build thread
The diesel ecu is different to the petrol afaik. And even then some are locked and others aren't. It's pot luck. Got it done at Vw village. Extra $130 for the unlock.
Not sure what the go is with those side lights I will have to pull a headlight out again.
Working on another secret project atm (rns related ) so will try and get around to it to see.
My RS build thread
the TDI engines have always been harder to "crack" with regards to ECU tuning.
likewise, the just because the same engine is used over at the VW stables, it doesn't mean the ECU will b the same - hence it may require different "cracking" methods.
MY17 Superb 162TSI, Business Grey, Tech+Comfort Pack, APR ECU+TCU Stg 1, SLA, Rieger Splitter + Side Skirts, Eibach Pro-Kit Springs, Hardrace Swaybar, TPMS
