Install of the JB1 was easy APART from removing the bottom tray and getting to that plug. Install prob takes 30mins in reality, maybe more on your first install if you are anal about making sure everything looks perfect and securing any loose bits with strategic zip ties. I then drove it on stock map +4.8psi coming on HARD between 2500 and 3000rpm. It is just too much torque for the FWD setup, there would have been over 400Nm in that sweet spot. It makes the car just too much mid-range and not enough top end. So now I use the custom curve and have a little bit of boost down low, coming in more progressively then filling in the region from 4000 to 5000 so it extends the torque curve a little higher and also fattens it up a bit. I took the JB1 off for service and the thing felt SO MUCH SLOWER !!
So it is definitely worth it but I would lower the boost from what the JB1 comes with standard. It is kind of fun using the mid-range torque when merging or on the highway. Nobody expect a station wagon to pull so hard onto highways or into gaps.
2015 Octavia VRS wagon - Manual
MY16 Octavia VRS Wagon, DSG, Race blue, Tech pack, Comfort pack, Black Pack, 19's, Sunroof, Electric Tailgate
Airbox mod, VW Racing Filter, TMD, Elbow, Ramair Pipe, GFB DV+, VCDS mods, Superpro adjustable rear sway bar, Superpro end links, Whiteline front sway bar links, Whiteline LCA bush Kit, Bilstein B14 coilovers, HPA dog bone mount & arm, 42DD oil catch can, Burger wheel spacers, CTS downpipe 200 cel cat, 2,5" exhaust , twin out. Super Skoda eyelids & front splitter, Tuned by BPS 228kw atw, Dsg tune,
Hey All
If you didnt know, Another great place for Skoda Mods
https://www.facebook.com/groups/504349199954332/
Jump on here mate
https://www.facebook.com/groups/SkodaModderz/
hey all, got a power run just to check things over with the JB4 custom map06 a few weeks ago. Here's the results (stock vs map06) pretty stoked, its an animal now. The midrange torque is awesome, hence the need for an uprated clutch lol.
2010 POLO 77TSI COMFORTLINE, CANDY WHITE, H&R 30/50 sport cup kit, 18x8 lenso speed 3
2016 SKODA RS230 WAGON, MOON WHITE, TECH,TAILGATE, P/ROOF, HP UPGRADED CLUTCH, JB4, DTE PEDAL BOX, EIBACH SPORTLINES, AVID1 18X8.5 AV20'S, CTS TMD/TIP, 034 DOGBONE INSERT, OBD11 MODS
