Page 41 of 45 FirstFirst ... 313940414243 ... LastLast
Results 401 to 410 of 445
Thread: Skoda Modifications
  1. #401
    Erskineville, NSW
    Quote Originally Posted by HPRS230 View Post
    Yea, the 18in wheels have about an inch or so to the front brake caliper.
    Ill keep an eye out and see what I can find.
    I might measure the distance from the centre line of the Hub to the brake caliper.
    Ask at BriSkoda.
    17" should fit on the 330mm (??) fronts. I know for a fact that 16" fit on the old 312mm fronts of the Mk2 vRS.
  2. #402
    Jun 2016
    Good Plan brad, as they all fit winter wheels
    Skoda RS 230
    "The Grey Ghost"
    SG-TP-AB RS230 - Timeline
  3. #403
    May 2012
    I was more so pointing out the gap (or lack of) like the pictured below.
    MY16 Candy white Octavia VRS Wagon, sunroof, 19" black pack, tech pack, comfort pack, auto tail gate
    MY12.5 Polo 6R GTI
  4. #404
    Aug 2016
    It's a piggy back unit for the ecu, and increases the hp/torque.
    How are you and Ferret getting on with the JB4? Have you done any logging/tuning with George @ BMS?
  5. #405
    Jun 2016
    Has anyone done a fuse tap in a mark 3 Oct?
    After power while ignition on. Only ones I can find is
    clutch/start stop - mini
    Rear wiper - normal size
    But you can't get a fuse tap as other larger fuse type things are in the way.
    Any help cheers
    Edit:
    Seems like spot 48 (not assigned) might work. Will keep you posted
    Edit 2:
    Yip that seems to work.
    Photos in timeline later
    Skoda RS 230
    "The Grey Ghost"
  6. #406
    Dec 2016
    Brisbane Qld
    Quote Originally Posted by pjam73 View Post
    Mine had been on map 2 for a 1000k's now no issues - we have a drive day coming up shortly at Lakeside where I can finally log some 4th gear wot pulls to get logs and map 6 customised
    MY16 Octavia VRS Wagon, DSG, Race blue, Tech pack, Comfort pack, Black Pack, 19's, Sunroof, Electric Tailgate
    Airbox mod, VW Racing Filter, TMD, Elbow, Ramair Pipe, GFB DV+, VCDS mods, Superpro adjustable rear sway bar, Superpro end links, Whiteline front sway bar links, Whiteline LCA bush Kit, Bilstein B14 coilovers, HPA dog bone mount & arm, 42DD oil catch can, Burger wheel spacers, CTS downpipe 200 cel cat, 2,5" exhaust , twin out. Super Skoda eyelids & front splitter, Tuned by BPS 228kw atw, Dsg tune,
  7. #407
    Jun 2016
    I haven't sent any logs to BMS as I'm still waiting for the lambda plugs. I've got a road lined up for testing lol
    Skoda RS 230
    "The Grey Ghost"
  8. #408
    Jun 2016
    RS230 update if you don't follow my time line.
    JB4 logs sent to BMS, without the air/fuel ratio wire tap, said it was a bit rich, but to be expected I guess as it doesn't know.
    Got video in motion enabled and ordered a wireless kit.
    Lambda plugs arrived so made a jump loom for AFR, installed wireless kit.
    Did another set of logs and sent to BMS with AFR. AFR is now closer to the 14s which is about right.
    I've also just ordered a DTE pedal box module (ex Germany/197.23 Euro) and should have Friday or early next week.
    Booked for dyno runs on Wednesday as well
    Bring on the track day!
    Skoda RS 230
    "The Grey Ghost"
  9. #409
    Bowral, NSW
    Sorry for delay.
    vRS TSI front brakes are now 340mm (Mk7 Golf R) - there are some, very rare but some, 17" wheels that fit on the Golf R. These are the ones you should be looking for.
    16" steel wheel was supplied for the spare on the Mk2 vRS because of the 312mm front brakes shared with the Golf GTI - but this is no longer an option.
    VW does not make a 5x112 17" steel wheel.
    2012 Octavia vRS TDI. Darkside big turbo, 3bar tune, other stuff. 200kW/650Nm.
    1990 Mk1 Cabrio. 1.9 IDI w/ 18PSI.
    1985 Mazda T3500 adventuremobile. 1973 Superbug. 1972 Volvo 144 in poo-brown.
    Not including hers...
  10. #410
    Jan 2016
    I did the JB1 module and used the custom map to have a progressive boost curve - maxing out at +4psi between 4000 and 5000rpm.
    Another good mod was the OBDEleven module. Besides convenience mods such as enabling Traffic and auto-close on the boot I also reduced the XDS, reduced torque steer compensation, changed the traction control to allow fully "Off" and reduced the rear brake on turn-in. The reducing torque steer compensation definitely brought some more feel to the steering and made it a nicer car in my opinion.
    2015 Octavia VRS wagon - Manual
