Page 25 of 45 FirstFirst ... 15232425262735 ... LastLast
Results 241 to 250 of 445
Thread: Skoda Modifications
  1. #241
    Mar 2007
    Melbourne, Vic
    I'd done a big post today in the group buy thread in the ice forum about my install experience from the weekend not realising kamold had already posted here.
    Couple of issues to note:
    1. The camera/boot release handle (like most of these Chinese Skoda accessories) are for the liftback model, which has different connectors everywhere to the wagon, for no good reason (eg the rear light clusters). So I had to put some wires into the connector and strip back a bit of insulation from the boot release motor wires to connect directly to. Also the shape of the new handle release is slightly different to the original and requires a bit of packing (I just used some foam rubber) under the metal cover to allow the screws to bring it in tight against the boot body.
    I have the liftback and the connector is wrong for it too. The one on the car is much smaller than the one on the handle. Mine was fixed with some dodgy soldering onto the pins on the handle and an excessive amount of hot glue to try to hold it all together.
    2. The reverse light power circuit is DIRTY. Massive interference on the image initially. Connected to constant 12v power from the boot release motor was very clean but the camera will burn out if its constantly powered. So the power needs to be filtered. The image is still not 100% clean but perfectly usable. Jaycar is your friend here.
    I also found the reverse light wire was only reading about 10.5v. I ran a separate power wire from the fuse box so I could install an accessories socket in the boot since the liftback doesn't come with one so I ended up using this switched by a relay I hooked into the reverse light wire so my picture is mostly stable now but I get a bit of tearing at the top of the image. I'll pick up the Jaycar filter on the weekend and hopefully that will fix it.
    I think with my camera it seems like it is slightly angled towards the kerb. Did you find this with yours? Would be nice if it was angled slightly lower so you could see the rear bumper.
  2. #242
    Bowral, NSW
    Have you got a stage2 ECU program with DPF regen removed? Did you get a discount given you only got the stage 1 recently?
    I had the Stage 1 done at VW Village for around $750 (complications with unlocker plus winter 20% off sale) total, then Stage 2 done at Peak Performance for a total of $100. Just had to show PP the VWV receipt and all was good.
    2012 Octavia vRS TDI. Darkside big turbo, 3bar tune, other stuff. 200kW/650Nm.
    1990 Mk1 Cabrio. 1.9 IDI w/ 18PSI.
    1985 Mazda T3500 adventuremobile. 1973 Superbug. 1972 Volvo 144 in poo-brown.
    Not including hers...
  3. #243
    Quote Originally Posted by Mysticality View Post
    Ah good to hear they look after you.
  4. #244
    Aug 2011
    Sydney Australia
    Hi All. Had my 2011 Octavia VRS (Manual) tuned with the Revo Stage 1 at Peak Performance yesterday. All I can say is Wow!! Without a doubt the best money I've spent on car to-date.
    One thing that had me a little concerned is when the technician installing the flash mentioned that the program could be lost if battery voltages drop, or if the battery is replaced. Has anyone experienced this before? or is there any truth to this? He mentioned they would re-flash at a charge of $40 however it seems a little inconvenient. I get that a Skoda dealer may overwrite the flash during servicing if an update is released by Skoda, however I was hoping the tune would survive a simple battery replacement.
  5. #245
    Jul 2013
    Caulfield, VIC
    There is absolutely no way a battery replacement would ever ever remove the tune lol. A battery is designed to get disconnected when servicing etc and nobody here has that problem. A dealer update is a concern but they are years and years apart no?
    www.TheRapidWrench.Melbourne
    The convenient, professional and affordable mobile bicycle mechanic that comes to you!
    My RS build thread
  6. #246
    Erskineville, NSW
    What MBM said. I've never heard of a tune disapearing if the battery goes flat or has to be replaced. Maybe Revo are weird? Flick an email off to the HO in the USA & ask them.
    Having an installer distributing info like that would make me lose confidence in the installer.
    A good battery place will hook up a 12v source while they do the battery - this will stop the ABS & steering wheel lights coming on on the dash.
  7. #247
    Oct 2009
    Mitchelton, Qld
    +1!!!!!!
  8. #248
    Aug 2011
    Sydney Australia
    Quote Originally Posted by donweather View Post
    +1!!!!!!
    Yep. The installer was not oozing confidence. He got the job done though and I received version 2 of the TSI Software. It definitely works
    Might consider using a more reputable installer next time but I doubt I'll be needing any more power at this stage.
  9. #249
    Bowral, NSW
    Quote Originally Posted by MountainBikeMike View Post
    +2
    The guy I dealt with at Peak Performance also never told me anything like that... But, then again, he did ask me "is the 125TDI a petrol or a diesel?" ...
    VW Village in Kensington seem to know their s**t.
  10. #250
    Apr 2014
    Frankston Victoria
    +2
    That's a worry when he doesn't know what "TDI" stands for!
