Page 21 of 45 FirstFirst ... 11192021222331 ... LastLast
Results 201 to 210 of 445
Thread: Skoda Modifications
  1. #201
    Jul 2013
    Caulfield, VIC
    Quote Originally Posted by joel0407 View Post
    Did they have to open up the ECU and solder on a new chip or was it done via the OBD port?
    Last time I checked they could map Tiguan ECUs but my Yeti. I dont know why as they are both the same motor so I would have thought VAG would use the same ECU.
    Happy Days.
    Bluefin uses the port in octys, should be the same...
    www.TheRapidWrench.Melbourne
    The convenient, professional and affordable mobile bicycle mechanic that comes to you!
    My RS build thread
  2. #202
    Newer ecus are encrypted and can't be flashed directly via odbII before they are unlocked.
    Sent from my HTC One using Tapatalk
  3. #203
    Bowral, NSW
    Grrrr!!
    I was hoping to be the first tuned diesel. :p
    Where'd you get it done?
    Definitely update with info!... And fuel economy!
    2012 Octavia vRS TDI. Darkside big turbo, 3bar tune, other stuff. 200kW/650Nm.
    1990 Mk1 Cabrio. 1.9 IDI w/ 18PSI.
    1985 Mazda T3500 adventuremobile. 1973 Superbug. 1972 Volvo 144 in poo-brown.
    Not including hers...
  4. #204
    Jul 2013
    Caulfield, VIC
    Quote Originally Posted by Mysticality View Post
    Grrrr!!
    If everyone else's mk2 fl octy works on a bluefin, shouldn't yours?? Hey did you see my post on the last page about the w5w globes
    My RS build thread
  5. #205
    The diesel ecu is different to the petrol afaik. And even then some are locked and others aren't. It's pot luck. Got it done at Vw village. Extra $130 for the unlock.
    Not sure what the go is with those side lights I will have to pull a headlight out again.
    Working on another secret project atm (rns related ) so will try and get around to it to see.
  6. #206
    Erskineville, NSW
    Quote Originally Posted by MountainBikeMike View Post
    Octy RS: installing sidelight (parker) bulbs- anyone know how? I couldn't get them out with long nose pliers despite twisting and clamping them. Just about pulled the wires out damn things
    This is for a pre-fl
    Did you remove the headlight assy from the car first?
  7. #207
    Jul 2013
    Caulfield, VIC
    Yes. I'm pulling on the back of the globe itself almost, where the wires go in, but for some reason the clip is giving me trouble and I can't see where I need to press or squeeze
    My RS build thread
  8. #208
    Erskineville, NSW
    There are differences. Some work & some don't. It's a crap shoot.
  9. #209
    Erskineville, NSW
    I thought it was a twist but I've never been in there, so don't take my word for it.
    What does it say in the owners manual?
  10. #210
    Jul 2010
    the TDI engines have always been harder to "crack" with regards to ECU tuning.
    likewise, the just because the same engine is used over at the VW stables, it doesn't mean the ECU will b the same - hence it may require different "cracking" methods.
    MY17 Superb 162TSI, Business Grey, Tech+Comfort Pack, APR ECU+TCU Stg 1, SLA, Rieger Splitter + Side Skirts, Eibach Pro-Kit Springs, Hardrace Swaybar, TPMS
