Hi here is mine with a reverse camera. I get the bars that change colour front and back. It is an aftermarket head unit with aftermarket camera integrated into the number plate light.
Pre facelift 2008. Tried with the short press ticked and not ticked (that's in the Navigation section).
Got the kit from carsystems.pl
2008 Skoda Octavia Elegance TDI 4x4 wagon
Bluefin 132Kw/385Nm, Racechips Response Control, Haldex Performance controller, H&R anti roll bars, Koni FSD shocks, SuperPro control arms & ball joints, subframe & gearshift mods, Full Dynamat interior, Polk Audio sound, Columbus, Bluetooth, MDI, parking sensors, camera. BBS SR 18x8" w/ 225/40xR18. 3M Crystalline tint.
Skoda Octavia Vrs 2008 TFSI Race Blue
| CC Phase 2 tune | BSH PCV revamp | DRL's | HID | LED's | 35% Tints | Towbar |es1099 HU | Rev. Camera | R8 Coils | Brisk LSG Plugs | Adams slotted Fr Rotors | Torque arm insert | 3" Down Pipe | High flow cat |GFB DV+ | VM Shifter Bushes |
I've just got a mount for a factory camera that just holds the camera by itself through a hole I'll need to cut. I bought the type that is integrated into the boot catch (the Tiguan version), but couldn't instal it because the boot catch connector was not the same as the Octavia and didn't come with a 'cup' on the back to hold it. Also not a neat fit once the hole is enlarged. The mount I have for the camera only requires a small hole and I can put it anywhere under the lip there is room. I took the camera out of the catch. Can't wait to put it in because vision out the back is limited.
Here's the fix:
Note! Skoda owners
Extract files PQTABLE and SKTABLE from image (use magiciso or ultraiso). Files can be found from path: \VUCI\B101\RNSMIDEC\PROG
Switch the filenames by just renaming SKTABLE to PQTABLE and vice versa
Overwrite the renamed files back to image and save the image. Burn this image to DVD or CD.
Load or reload the Firmware to your RNS-510 using the steps below.
Voilá… buttons are back!
Good result!
Sent from my GT-N7100 using Tapatalk
