Hey Lucas_R,
Cheers for the feedback, yea I not keen on spending heaps
Hey Lucas_R,
The Grey Ghost now Stops, turns and puts power down again. Falken FK510 now on the car 235/35/19 fit perfectly. Will drive for a while but initial thoughts coming from a 2015 P zero's are out of this world lol.
Skoda RS230
New rear pads today, found that the rear rotor minimum spec is 8mm, and have about 10mm after 3years. Pads have done well....
Went with stock rear pads as the rotors were still in spec, was looking at T2 and FP2 set up, but thought I'd save the cash.
Car is 3 years old (to us) on the 10th, how time flys aye!!!
Skoda RS230
Saturday service
My 6 months service is mainly a oil change, but Ive also done:
Changed back to stock air filter to clean the foam one
Re adjusted my shift cables (manual box)
Re oiled DVX BOV plunger
washed air intake plastics
Bleed clutch and brakes
Managed to find time to clean the foam air filter, dry it and re spray it, installed last night ready for happy laps this morning.
Sessions now have a speed limit down the main straight, so the oil temp never got over 110.
This afternoon re bleed the brakes just to get the pedal back after half an hour of hard stopping.
The FK510 tyres worked well and was very happy with the grip they had, started the pressures alike to low so took a while to come up, but we're stable around the 38psi mark.
Got some bits coming so look out for that soon
Skoda RS230
hi mate, I just noticed you have exhaust wrap and turbo blanket fitted. have you checked the temps to see if it made any noticeable difference?
I'm struggling with high oil temps at the moment and looking for solutions but I think an oil cooler will be inevitable...
Hey Bud, I did a few things at once so can't say exactly what brought oil temp down. I sit around 110 where as I was up around the 115 on the motor way cruising.
That was the grill cut out, oil housing cooler, wrap and turbo blanket.
Yea a couple have done the racing line oil cooler with reasonable success, but even 1 guy still has high temp and he has the steal oil pan with larger capacity.
Hopefully that helps (maybe)
Skoda RS230
Chargers are suited to some or many types of battery construction (AGM, Gel, Ect). Charger won’t care if the car has stop/start.
Just need to make sure the charger does that type. Most of the new CTEK do a variety so should be fine.
Just had to replace mine after 4 years. I drove to the shops fine. Wouldn’t start when I went to leave. Lucky super cheap was next door so I got a small jump pack.
Tried to charge it when I got home but it would say charged after 5 minutes. Got out the tester and it had Dropped 2 cells. No warning at all.
Because I tried to start it when it was really flat it induced so many fault codes. Had to clear them after the new battery. Take it for a spin then clear the rest.
I’d get a new one before it goes in a big way. You will have to do the coding once It’s changed as well.
