Originally Posted by
HPRS230
Did Happy laps on Sunday just gone, Car felt really good and Pulled nicely. Clutch feels stock, if not a touch softer.
The only problem was the Brakes while on Track... Hopefully I can save the pads and just bleed the system.
Service and Airbag replacement Book for Nov, Ill also get Dealer to drop the VAQ Diff Oil and Clean the Filter, as I've read a few Golf R's having Problems around the 3 year/60k km mark, So Ill get that done a year early. I'll also try and get them to up the Oil to 5W-40 (normally 5W-30).
Been on the hunt for Rally Style Mud Flaps, very keen on the Rally Armour but no Skoda kit, but I have Emailed to see if the GOlf Mk7 ones will be ok. The Skode front inner guard mounting holes are more in-board than a MK7 Golf GTI, so the front may not stick out as far, but the Rears should be ok, Which is what I want as the Rear bumper is starting to get ripped up.
Major Mod next will be Brakes I think. I wont be doing any Suspension Mods (Lower control Arms, Springs, Dampers, Coilovers) as my drive way is so bad plus its a daily driver with the odd track day, not the other way round. On that note,
I'm also on the look out for Spring Rubbers to increase the Spring Rate for track use, Yes it raises the Ride height, but stifferning the spring will help cornering a touch I feel.
