#SkodaWednesday with Ferret VRS,
The Grey Ghost got its CTS Turbo Muffler Delete (TMD) and Turbo Inlet Pipe (TIP) plus a road test.
Have the JB4 on map 2 masks what improvement there is, but on stock you will def feel it!
#SkodaSunday with FerretVRS, ticked over 7500km so dropped to oil.
While under the car, got a photo of the 'Diff'
Skoda RS230
On #SkodaSaturday with Ferret VRS, Installed the CTS Turbo Short Shifter, bushes and also did the clutch master to slave mod, taking the restrictor out.
Went with 35% reduction in throw, which I may move it to 20% reduction.
Stock was 65ish mm (3rd to 4th), and now it's about 45ish mm. Need a lot more force as it moves the pivot point.
http://bd8ba3c866c8cbc330ab-7b26c6f3...it_Install.pdf
Free MT6 wonder mod: OEM bleeder delay removal - GOLFMK7 - VW GTI MKVII Forum / VW Golf R Forum / VW Golf MKVII Forum
http://www.ctsturbo.com/cart/CTS%20S...structions.pdf
Dam... I'm new to this forum but your car is all sorts of nice, mate! Congrats!
Cheers! Unfortunately I started back from the 1st post so by the time I read your last post, it was too late... hahaha Soooo many ideas now!
What's this clutch master to slave mod all about?
Removing flow-restricting diaphragm in the hydraulic line between the master cylinder (clutch pedal) and the slave cylinder (transmission).
