We Posti tap'ed my Mates Golf R, seems fine.
I had ordered plugs from Audi (lambda side) and wire with pins, and also ordered the ECU side from china before I'd really worked out what the go was.
China sent 4pin not 5pin plugs, so have to wait a week (ex UK).
I think a few have done what Im trying to do, but its not cheap.... $115 for a plug and 5 wires/10 pins attached....
Ferrert had time today to cut the blanking plates in the grill, so now we have the full Ferret airbox mod
Starting to plan whats next for the RS230 ..... but the 'minister of finance' has cracked it, so everything is on hold till march/April.
Planning to order:
Internal TPMS - TICK
DashCam
A huge Superskoda order
Maybe Track wheels and tyres.
Im keen to get the RS230 rims from superskoda, but will most likely go with some 2nd hand wheels locally
TPMS ordered..... Should have them installed this weekend
So had a bit on this week.
- Meet up with Spinifex to enable Video in Motion. Now I have to work out if I need to buy the JB4 wireless kit to display the gauge set...
-TPMS arrived today, so got the sensors fitted at Toombul Bob Jane for a box of Beers, If you need anything to do with tyres, make sure you go there, I've been using them for 5 years!
- On the Way home this afternoon, I hit 3000km.
- Once home, mounted the Display and ran the RF wires.
- 1 wire along the plastic sill cover and up the to rear door
- the other behind the dash and in to the engine bay by the left front head light.
This should give it a good signal.
Off tomorrow to get a Fuse Tap and run 12V behind to the drop down bin above the drivers knee, so the TPMS has power.
I've got an 4 way ciggy box, so will mount that inside.
I was gutted to find the fuse box is not on the ends of the dash like I had read on Briskoda, but this will still work fine. Just have to run a longer cable.
