Page 6 of 21 FirstFirst ... 4567816 ... LastLast
Results 51 to 60 of 202
Thread: SG-TP-AB RS230 - Timeline
  1. #51
    Aug 2016
    Quote Originally Posted by HPRS230 View Post
    Is that the thing do to do is it? TTRS clutch? That would definitely help!
    I believe so, at least from reading golfmk7.com forums. Basically, you can put together a collection of OEM parts that include parts from the TTRS clutch. This is an alternative to getting an uprated after-market clutch, and they believe that some of those kits are doing the same thing (OEM parts slightly modified). One such highly rated clutch is the RSR Clutch from HS Tuning:
    HS Tuning RSR 2.0T Clutch Kit - HSTRSR1
    Here's the thread on building your own "TTRS" clutch:
    Official DIY TTRS Clutch Kit - GOLFMK7 - VW GTI MKVII Forum / VW Golf R Forum / VW Golf MKVII Forum
    MY16.5 Octavia RS wagon, manual, Moon White + tech pack + 18" black pack.
  2. #52
    Aug 2016
    There's also the Sach's clutch that reviews well, note that we get 19% off too being outside the EU:
    https://www.sachsperformance.com/en/...-001422-999502
  3. #53
    Sep 2012
    Do you have any photo of the underside of your car? I'd love to see the difference in exhaust setup to standard so I can try to emulate in the aftermarket. The APR drop in 'turbo muffler delete' seems to be a lot off effort for little gain in value or exhaust note improvement. I'm looking for a little more noise without being rude. I think the RS230 achieves this but i'm not sure exactly how.
  4. #54
    Sep 2010
    QLD
    From the other forum, RS230 has a smaller diameter cylindrical mid muffler as opposed to the prism like mid muffler on the RS220, length wise is the same I believe.
    I don't believe the turbo muffler delete does anything in regards to the muffler note, its more for the noise of the turbo itself. I might be wrong here.
    If you want improvement on the exhaust note, changing mid muffler is the easiest and cheapest way, I did and is very happy with the result. Find one that is steel packed and the longest you can fit there (OEM is 24 inch long). Newer RS has a band clamp around the mid muffler instead of one solid pipe, which makes things a bit simpler.
    2011 Tiguan 125TSI - SOLD
    2014 Race Blue Octavia RS 162TSI Combi
    Check out my leather work ----> http://pedsnro.blogspot.com/
  5. #55
    Jun 2016
    Briskoda has some info about the 230 pipes as well.
    Skoda RS 230
    "The Grey Ghost"
  6. #56
    Sep 2010
    QLD
    You might want to use a selfie stick or jack one side up to take a photo, it's very tight down there.
  7. #57
    Jun 2016
    Around Post 21 28/39 has photos, 48 has part layout
    My photos will not be that good.... as the car is in the air. in post 39.
    How does the VRS 230 exhaust sound thing work? - Skoda Octavia Mk III (2013 onward) - BRISKODA
    Skoda RS 230
    "The Grey Ghost"
  8. #58
    Sep 2012
    Mine photos will not be that good.... as the car is in the air. in post 39.
    Thanks for posting that link, had a read through it all. Looks like the rear silencers have different part numbers also. It would be a big job to swap is all over to RS230 parts. Might try and have a look under mine to see there there is a slip join with a band clamp as per 99Reza's suggestion either end of the centre muffler. Id like to make is as easy as possible to put back to stock if it doesn't work out.
  9. #59
    Jun 2016
    JB4 installed....
    Awaiting the Lambda Plugs to hook up AFR, then off to the Dyno
    Skoda RS 230
    "The Grey Ghost"
  10. #60
    Aug 2016
    JB4 installed....
    So you're not happy with using the supplied PosiTap connection? Has anyone else come up with a workaround or are you the pioneer?
