Page 16 of 21 FirstFirst ... 61415161718 ... LastLast
Results 151 to 160 of 202
Thread: SG-TP-AB RS230 - Timeline
  1. #151
    Jun 2016
    So much for not having much planned...
    Fedex shipment arrived at work today from ESC tuning, with the CTS oil cooling housing and a forge turbo blanket. I've got some exhaust wrap also coming and plan to wrap the CTS downpipe.
    Will do a diff service as well as the car will be in stands to remove the downpipe.
    Also in the list is the cut out the grill to increase the flow by 50%
    I'll grab some photos, should be doing it this weekend.
    Skoda RS230
    Skoda RS 230
    "The Grey Ghost"
  2. #152
    Jun 2016
    Big day today, but Unfortunately didn't have time to get progress photos.
    Day started with a wheel alignment, was out a bit.
    Downpipe out and heat wrapped, sounds a lot better now, it's lost its tinny-ness.
    Forge turbo blanket on, needed to remove heat shield, like 4 bolts.
    Both these should keep some heat out.
    CTS oil housing with cooling fins, oil temp was a touch lower on the first drive, and it seemed to take a little longer to go from 90 to max temp.
    Also cut the other half of the front grill out, which should help with air flow...
    While the car was in stands, dropped the VAQ Diff oil and replaced the 2 bolts and about 250-300ml of new oil.
    Now to tune the JB4 and have emailed BMS for tuning review.
    Also the HPA puck has blown out but a replacement is on the way. So great service from them.
    Got the GFB DVX coming too to help throttle response and the dvx has a blow off valve so that should be fun....
    Skoda RS230
    Skoda RS 230
    "The Grey Ghost"
  3. #153
    Jun 2016
    GFB DVX installed... Sounds like a rally car from the 90s now Thanks to a fellow member, However it is illegal to Vent to atmospheric in QLD so 0 vent while on road
    Will need to re run the catch can hose as it doesn't look healthy is current spot
    Also put the JB4 back to Map 6 with a max of 22psi, Ive got happy laps in a few weeks to tune it up a bit more.
    SG-TP-AB RS230 - Timeline-1-jpg
    Skoda RS 230
    "The Grey Ghost"
  4. #154
    Jun 2016
    So....
    Happy Laps at Queensland Raceway killed the 2nd hand Remsa Pads... Which I thought would happen, they were Killed the first time at QR...
    So just ordered DBA T3 Rotors and Forza FP3 pads with some High Temp Brake Fluid from Brakes Direct.
    SG-TP-AB RS230 - Timeline-qr-jpg
    Skoda RS 230
    "The Grey Ghost"
  5. #155
    Jun 2016
    Tool Tuesday...
    Oil drain plug tool for those playing at home
    Oil Pan Drain Plug Screw Removal Install tool for T10549 VAG VW Audi Skoda Seat | eBay
    SG-TP-AB RS230 - Timeline-oil-jpg
    Skoda RS 230
    "The Grey Ghost"
  6. #156
    Jun 2016
    Managed to Find time and Install the Brakes tonight,
    Feels way better now, so they will only get better
    Skoda RS 230
    "The Grey Ghost"
  7. #157
    Jun 2016
    So... This happened today
    RACQ has ordered a new OEM screen, and it will need to be Re-Calibrated as I have Tech pack
    35mm Dia so they wont repair it.
    SG-TP-AB RS230 - Timeline-front-screen-png
    Skoda RS 230
    "The Grey Ghost"
  8. #158
    Mar 2019
    Nice thread, I enjoyed the read Hamish.
    2018 Skoda Superb Sportline Wagon (MY19)
  9. #159
    Jun 2016
    Quote Originally Posted by aratic View Post
    A bit you can do to yours now...
    Skoda RS230
    Skoda RS 230
    "The Grey Ghost"
  10. #160
    Mar 2019
    Maybe, we’ll see SG-TP-AB RS230 - Timeline
