Page 15 of 21 FirstFirst ... 51314151617 ... LastLast
Results 141 to 150 of 202
Thread: SG-TP-AB RS230 - Timeline
  1. #141
    Jun 2016
    Today was the day the NPC Kit (above) was installed at Bayside Performance Services, and top blokes they were.
    The 2min drive review.
    - 0-2000rpm on or off throttle there is chatter (but racecar)
    -The bite point is just off the floor (but racecar).
    I would say that both these features will get better with time.
    It has 30km of driving.
    - The pedal feel however is stock
    I was going to baby it for 1000km as recommended by NPC, but Ill re-install the JB4 at the weekend and do the odd pull every now and then over the 1000km, see how shes holds.
    NPC
    "The recommended bed in period is 1000km’s of regular driving.
    Avoid any clutch dumping during this period. You can lean on it but don’t go thrashing the car in this time.
    If the clutch does slip then get off the pedal immediately and let the clutch settle in more.
    1000km’s on the highway will not bed the clutch in. You need to drive the vehicle around town and go through the gears as much as possible because the engagement of the clutch is what settles it in."
    Skoda RS 230
    "The Grey Ghost"
  2. #142
    Jun 2016
    How good is FedEx from USA! Ordered Sunday Night Aus time, had it Thursday lunch time!
    The side to side gear selection feels a bit sloppy, so had a look at the retaining clip for the cable is a bit stuff, (install error day 1),
    So got the ECS Tuning side to side kit, and a Alignment pin.
    So will install that this weekend, May leave it on the stock feel, but might go 20% reduction, will see how it is. Will all so do a Brake and clutch Bleed, reinstall BMS catch can to Engine mount.
    Got a nice 4 inch Dial Tyre Pressure gauge for track days, and ordered some stickers for the helmet Ill be getting soon.
    Clutch is feeling better, so hoping a bleed will make it better again, then it will be dyno time....
    Skoda RS 230
    "The Grey Ghost"
  3. #143
    Jun 2016
    Skoda Sunday...
    Re install BMS catch can to the engine mount.
    Replace side to side shifter arm with the ECS Tuning unit. Has made the side to side a lot nice. Left as stock position, may go 20% reduction but don't want to make it easy to achieve a 'Money Shift'....
    Cleaned out intake track with a can of SCA intake cleaner, bleed brakes and clutch.
    Found front tyres are well shagged, so will sort them out this week
    Skoda RS230
    Skoda RS 230
    "The Grey Ghost"
  4. #144
    Jun 2016
    New P Zeros on today, the Current Tyres have lasted bang on 24,000km, Prob not bad for the hard life they have had....
    Once I'm happy, Ill start turning on Starting Vibration and Lock Elec Diff setting via OBDeleven to get a bit more traction, along with go to map 6
    Should be a bit of a weapon again!
    Skoda RS 230
    "The Grey Ghost"
  5. #145
    Jun 2016
    Got the green light to run the Map 6 from BMS, go with that, I'm booked for happy laps at lakeside to get some better logs and hunt and pass a few fast cars....
    Skoda RS 230
    "The Grey Ghost"
  6. #146
    Jun 2016
    Did Happy laps on Sunday just gone, Car felt really good and Pulled nicely. Clutch feels stock, if not a touch softer.
    The only problem was the Brakes while on Track... Hopefully I can save the pads and just bleed the system.
    Service and Airbag replacement Book for Nov, Ill also get Dealer to drop the VAQ Diff Oil and Clean the Filter, as I've read a few Golf R's having Problems around the 3 year/60k km mark, So Ill get that done a year early. I'll also try and get them to up the Oil to 5W-40 (normally 5W-30).
    Been on the hunt for Rally Style Mud Flaps, very keen on the Rally Armour but no Skoda kit, but I have Emailed to see if the GOlf Mk7 ones will be ok. The Skode front inner guard mounting holes are more in-board than a MK7 Golf GTI, so the front may not stick out as far, but the Rears should be ok, Which is what I want as the Rear bumper is starting to get ripped up.
    Major Mod next will be Brakes I think. I wont be doing any Suspension Mods (Lower control Arms, Springs, Dampers, Coilovers) as my drive way is so bad plus its a daily driver with the odd track day, not the other way round. On that note,
    I'm also on the look out for Spring Rubbers to increase the Spring Rate for track use, Yes it raises the Ride height, but stifferning the spring will help cornering a touch I feel.
    Skoda RS 230
    "The Grey Ghost"
  7. #147
    Jun 2016
    Reset the Tyre Pressures after the Track session.
    Very Happy with how the InaWise TPMS is going.
    SG-TP-AB RS230 - Timeline-tyres-jpg
    Skoda RS 230
    "The Grey Ghost"
  8. #148
    Mar 2013
    Newcastle, NSW
    Quote Originally Posted by HPRS230 View Post
    How's the clutch take-up point and chatter now that it's had some time to bed in?
    I've had a tune done to my 162tsi manual and 4-5-6 is starting to slip! Very keen to look at clutch options.
  9. #149
    Jun 2016
    Quote Originally Posted by Pulse66 View Post
    OH NO not slip! sorry for your lost mate. Mine got to the point I couldn't use ACC on the motorway lol
    NPC heavy duty Organic Clutch (NPC make the Harding Performance kit) with is a single mass unit.
    The Feel: Same same, if not a touch softer
    The Take up: its still right at the bottom, ie not a lot of travel
    - I had to remove a couple of washers from my clutch stop so it felt like it had some travel....
    - I have taken out the bleed restriction, which might help bring it a touch higher, maybe not sure
    The Chatter: Yes there is chatter, not sure if we have gotten use to it, or its a lot quieter.
    - It was like rocks in a bucket, so maybe it is a bit better with a few km on it.
    Hope that helps mate.
    You on the Facebook page SkodaModderz?
    Skoda Modderz Public Group | Facebook
    Pulse66, There is a mk7 Clutch thread here btw
    Mk7 Golf Manual Clutch Issues, Discussion and Questions
    Skoda RS 230
    "The Grey Ghost"
  10. #150
    Jun 2016
    Did a tyre rotation today, pulled the pads and they were nearly on the wear indicators, another member was helping and had a 2nd hand set he had swapped out due to track performance wasn't that good, Remsa pads. Rotors were still with in spec so will see how they go. Quick brake bleed as well.
    Once the rotors are out of spec, I'll prob get a set of DBA T3 slotted.
    Nothing else really planned for a while.
    Intercooler and real tune is still in the list, along with the LCA and new tyres....
    Skoda RS230
    Skoda RS 230
    "The Grey Ghost"
