Page 3 of 7 FirstFirst 12345 ... LastLast
Results 21 to 30 of 63
Thread: Scum in coolant reservoir
  1. #21
    Sep 2016
    Hmmmm, yours isn't that old either.
    Wonder if the radiator/cooler assembly on the Skoda's is bespoke, or just VW stuff?
    Surprised the engineering hasn't been improved on them though - the oil cooler leaking into the radiator has been a known issue on VWs for years apparently......
    2016 Skoda Octavia 162TSI RS Wagon
    (Race Blue, DSG, Tech pack, Comfort pack, 18" Black pack, panoramic sunroof, auto tailgate)
    Previous: 2012 Mazda 6 Diesel // 2001 Subaru Liberty STi // 1991 Subaru Liberty RS Turbo // VK Holden Commodore // Subaru Leone // Mazda RX-808 // Mitsubishi Magna // 1971 Mazda R100 Coupe
  2. #22
    Dec 2008
    Sydney/Canberra
    Scum in coolant reservoir-781115090-jpg
    I would say the suspected faulty parts are 1, 7, 15, and 16.
    1 is the main bracket that supports the alternator, the a/c compressor, the oil filter, and the oil cooler. Has engine oil and coolant passing through it.
    7 is the seal to the engine block.
    15 is the oil cooler. This has engine oil and coolant passing through it.
    16 is the seal between the cooler and the bracket.
  3. #23
    Sep 2016
    Ahhhh...... so I'm not sure which parts are being ordered from overseas.
    All the service agent told me, was the the radiator & oil cooler were one-piece, and that parts had been ordered from germany.
    What those parts were, I'm unsure.
  4. #24
    Dec 2008
    Sydney/Canberra
    They may well be ordering a radiator too, as it will be pretty clogged up.
  5. #25
    Correct me if I'm wrong, but wouldn't this have messed up engine/turbo cooling pretty badly and also cause coolant to get into the engine oil? Or was it just a leak into the radiator, still a messy and pretty bad problem all around.
  6. #26
    Dec 2008
    Sydney/Canberra
    Radiator is just a radiator on these. No internal heat exchanger for oil in them.
    Oil in the coolant is more obvious, compared to coolant in the oil. Always best to treat it as if both have occurred.
  7. #27
    OK to put it another way, from your diagram, there was a leak in a part that had separate oil and coolant pathways, so they mixed right?
  8. #28
    Dec 2008
    Sydney/Canberra
    Correct.
  9. #29
    Geeze it was bad enough when just the headgasket was all you had to think about, when did it become a good idea to make some more points for things to stuff up....
  10. #30
    Dec 2008
    Sydney/Canberra
    At least head gasket failures in VAG stuff are pretty rare these days.
