Page 1 of 14 12311 ... LastLast
Results 1 to 10 of 140
Thread: Scout or Yeti?
    Apr 2011
    Townsville, Qld
    Scout or Yeti?
    Trying to decide which to get, Scout or a Yeti. What do you think?
    Requirements and needs:
    Driving myself to work on sealed roads.
    Enough space to fit 6 medium size dogs maybe once a year.
    Space for 2 or 3 20kg bags of animal feed, plus groceries, maybe the odd bale of hay.
    Need high water clearance for wet season flooding.
    Need good stability, traction and safety for same reason.
    Need get up and go for overtaking road trains, but not a speedster, currently drive a Holden Astra wagon (aka Vauxhal Opel I believe) and happy with the speed and handling of that.
    Drive about 600km a week
    Diesel
    Manual
    No off road but want the security of having the extra traction of 4WD/AWD if I need it.
    The Yeti is probably what I need but I am concerned it will be too small. Although I can take those seats out if I need to transport the dogs. I wouldn't want to be doing that every two weeks when I get bags of feed though.
    The Scout seems to have the space I am used to, but the Yeti sounds like it will be more capable with thunderstorm, flooded roads and wet season driving. This is a decider for me. I do not want to be stuck on the road or feel unsafe with a tropical storm raging around me. I don't find it exciting or amusing.
    From what I can find out, they both have the same wading depth. Both seem like they will do what I need.
    At first I was set to buy a Tiguan but then I discovered the Yeti, and now the Scout. Took a Tiguan for a test drive and it was very nice, but I hate the button handbrake. I want a 'real' handbrake! Also seems like better value for money to get a Yeti now.
    Taking Yeti and Scout for test drive, hopefully next week. Just wondering what other people think are the pros and cons. For anyone who may have chosen between the two or the Tiguan, what influenced you and has it turned out as you thought after buying?
    Cheers,
    Michelle
    Jul 2010
    Emu Plains, NSW
    Hi Michelle,
    Were it me and that list of needs (inc 4x4) was mine, it'd be a Scout for me (assuming your budget is closer to $40k than $30k). It's larger, more useable boot space, arguably will handle better on sealed roads, available in diesel 4x4.
    Eg the extra boot space was a clincher in my decision to buy an Octavia RS wagon over a Golf GTI, and by the sounds of it you need boot space for your hay and dogs etc... I don't often fill my boot but it's there when I need it and there've been times I'm glad I've had that much boot space! In the end it's gotta be better to have it when you need it rather than be left with half your goods sitting on the ground wondering why you didn't get something with more boot space to suit your needs.
    BTW if they've both got the same 'wading depth' than I fail to see how the Yeti might be 'more capable' in a storm? I see no advantage of being in a Yeti compared to a Scout then while driving thru some minor floodwater (if that's what you do).
    Jun 2009
    Hi Michelle,
    I'm going to have to disagree with RSOK and say get a Yeti. From what you said, it sounds like the Yeti is perfect for you. Yes the Scout's boot is bigger with the seats up but with the seats down the Yeti is a good 300 litres bigger and the rear seats are much more useable in how they slide/recline/fold/tumble/come out. To fit 6 'medium sized' dogs into a Scout you'd still have to fold the seats down anyway.
    The Yeti is more capable off-road because it's shorter with way less overhang on each end - meaning there's less chance of scraping it off-road and it's a newer system with the 'off-road' mode with hill-descent control - it's Skoda's first proper 4WD. The Yeti is also a lot newer (the Octavia is being replaced next year) and a lot funkier/cooler! The Yeti has won many awards, including a few car of the year awards, the Scout has not. But the Scout is better value though (despite the Yeti's on-road price being the Scout's RRP).
    In the end both are great choices (certainly better choices than the Tiguan) and I wish you luck with your purchase!
    Mine: Silver 2006 Volkswagen Golf Sportline 2.0FSI 6M (with a sunroof)
    Parents': Candy White 2008 Skoda Octavia RS 2.0TFSI 6M Liftback
    Adelaide hills, SA
    Hi Michelle,
    go to the dealer take everything that you need to fit in your new car with you and try fitting it in the Yeti and Scout and compare them both, that's what I would do. Or borrow the car for a day and see how it fits your requirements.
    Jul 2010
    Emu Plains, NSW
    Quote Originally Posted by Jake02 View Post
    Hi Michelle,
    No doubt Jake Yeti's rear seats are more practical in terms of moving (removing?) them to change up the cargo space, can't disagree there. If Michelle needs to often carry more gear than the Scout's big boot can swallow with the rear seats in place then this is somethig she may want to take a closer look at.
    But given Michelle has stated "No off road" I'm not sure she'd be looking to utilise Yeti's shorter overhangs or newer hill-descent controls.
    Certainly agree either car would make for a happy owner, and as Transporter says a test drive and "real-world" loading scenario would pretty much decide it for Michelle.
    Apr 2011
    Townsville, Qld
    Well, that's one for a Yeti and one for Scout, and one for either lol, which reflects exactly where I'm at!
    I guess my reason for thinking the Yeti would handle better is just that it 'looks' more like a 4WD with the higher stance. Conversly though, that really means it's probably not as safe since it has a higher center of gravity than the Scout, which would hug the road more.
    I am probably leaning to the Yeti because it will be easy to slip into any park,and spaces are getting microscopic now at the new ticky tacky box shopping centers springing up everywhere. I used to have a Festiva years ago and I could park that thing nose first anywhere, anyway. Never had to reverse park once!
    I want to balance my desire for space against the practicality of driving for most of the time with just me in the car. On the other hand, I don't want to be shifting seats around in the Yeti every fortnight, no matter how easy it might be. I guess so long as I have enough room in the boot to fit the feed, I can always throw the groceries on the rear seats, which is what I do now if I only have a few things.
    I am looking forward to the test drives next week. Transporter, do dealers down south really let you guys take a car for a whole day? They looked at me sideways here when I wanted to take the Tiguan for an hour and a half so I could test it on the stretch of highway I am familiar with. And I had to book that in advance.
    However, on the minor point of aesthetics, the Yeti is just plain weird and reminds me of an old Terios while the Scout has a more elegant look! Heh heh.
    Judging from I can see the Scout will have a much larger load area than the Yeti.
    If you can handle a manual have you looked at the equally visually challenged Subaru outback diesel?
    Oct 2009
    Carlton, NSW
    Two different beasts of course. The Octy is a great load carrier, (Had a house front door in mine yesterday!) but having owned an Octavia wagon (Same size as Scout -roomy but cant imagine having six dogs in it - my two are enough!) and a Roomster (Same removable varioflex seating as the Yeti), my hands down choice for a dog box would be the Yeti. Why? - Flat floor so no drop into boot, Yeti back seats fold right out of the way (or out of the car if need be). Your Scout back seats could get easily trashed by the doggies while your Yeti seats can be out of harms way.
    On the other hand you do a lot of driving and I think the Scout / Octavia will probably be a better drive than any SUV short of an X3/5.
    So I have been no help at all really. : - )
    just my 2 cents..
    Apr 2011
    Townsville, Qld
    I'm not sold on the Subaru I'm afraid. I did look at them in the first instance when I looked at the Tiguan, ASX Aspire and RAV4 but I have to say the finish and quality of the Euro cars seems to be a fair bit ahead of the Jap cars. The Subaru is still prettier than the Yeti though!
    Flat floor for the dogs is a bonus. That is good to know. I've discovered 'flat' seems to be open to interpretation as far as some salespeople are concerned. One thing I dislike about the Astra is that, although the seats do fold flat, the seat part when folded up remains loose and wobbles around in a very annoying way. How hard can it be to have a little locking lug?
    As for the amount of driving, yes, I am looking for a bit of comfort I must admit. The Astra seats are ok but not as nice as lumbar support would be.
    I've just noticed that the Scout has a 6 stack CD as an option...wha? I'm not a luddite exactly but not into ipods and so forth, is the mp3 thing meant to take the place of cd player now?
    Jun 2009
    Quote Originally Posted by Michelle View Post
    If you don't like the look of it then buy the Scout, lol. Problem solved . I'm the opposite; I can't believe that the foglamps being put into the headlights slightly could make people think so little of the styling. Each to their own really. I like it because it's different - it's not ultra-convservative like every other car on the road!
