Results 1 to 9 of 9
Thread: RS Octavia DSG MY11 Clock Spring Control Unit Slip Ring
    Mar 2016
    5044 SA
    Hi,
    Hope someone can help
    I have the airbag light on and the steering controls dont work.
    I had it scanned and they said it was the clockspring, but quoted me $1500 to fix!!!
    I pulled the wheel off and the part number is 5KO953569B so im trying to find out which variant I can buy
    Ross tech has the list of modules Steering Wheel Control Module Versions - Ross-Tech Wiki
    Part Number 5K0-953-569
    • MFD = Multi Function Display / Board Computer
    • CCS = Cruise Control System
    • ACC = Adaptive Cruise Control
    • MFSW = Multi-Function Steering Wheel
    • AT = Automatic Transmission (Ignition Key Lock)
    Control Module Part Number Variant MFD CCS/ACC MFSW AT
    5K0-953-569 Midline Yes Yes - Yes
    5K0-953-569-A Highline Yes No Yes Yes
    5K0-953-569-B Highline TBD TBD TBD TBD
    5K0-953-569-C Midline Yes Yes No TBD
    5K0-953-569-D Highline TBD - TBD TBD
    5K0-953-569-E Highline Yes Yes Yes Yes
    5K0-953-569-F Midline TBD TBD TBD TBD
    5K0-953-569-G TBD Yes No Yes Yes
    5K0-953-569-H Highline Yes Yes Yes Yes
    5K0-953-569-J TBD TBD TBD TBD TBD
    5K0-953-569-K Highline TBD - TBD TBD
    5K0-953-569-L Highline Yes Yes Yes TBD
    5K0-953-569-R Highline TBD TBD TBD TBD
    5K0-953-569-S Highline Yes - Yes Yes
    5K0-953-569-T Highline Yes Yes Yes Yes
    5K0-953-569-AA Midline TBD TBD TBD TBD
    5K0-953-569-AB Highline TBD TBD TBD TBD
    From looking at this I need the highline with 'yes' in all columns. So it would be the 'B' which is the same or 'H' or 'T'
    I found the 'H' here www.skodateile.cz
    'T' here VW CC Passat B7 CC 3C tempomat elektronische modul 5K0953569T 5K0 953 569 T in neue vw oemHighline elektronischen baugruppen( Schlupf Ring) passat b6 b7 cc Teile-nummer:5k0953569t aus auf AliExpress.com | Alibaba Group
    Can anyone shed some light on which version I can buy that will work?
    And
    Any other suggestions of where to buy it from?
    Thanks
    Clock springs were an issues in a number of cars due to dodgy airbags (separate to the Japanese issue of shrapnel in the face) I know lots of Hyundais had it with their supplier. Haven't heard of if in VAG cars. Might be worth checking it's not a known problem about to be recalled. Certainly I'd be gunning for it to be covered under good will as an airbag woukd be expected to last at least 10yrs.
    Mar 2016
    5044 SA
    yep there is one on is the US VOLKSWAGEN ISSUES VOLUNTARY RECALL : Volkswagen US Media Newsroom
    same part as best as I can tell, not sure why its only US....
    Dec 2007
    ivanhoe vic
    Good luck with VW locally. Where are you based I got my Passat fixed for $400 - $1500 is. Joke
    B6 Passat Wagon No KESSY
    I reckon there is enough of a lawsuit waiting there that they should cover it under goodwill.
    Dec 2007
    ivanhoe vic
    Good luck I have tried with VW before
    Mar 2016
    5044 SA
    I'm in SA, where did you go to get yours fixed OilBurna?
    or can anyone in SA recommend a place to go to ?
    Thanks
    Dec 2007
    ivanhoe vic
    I was in Vic sorry
    Mar 2016
    5044 SA
    For anyone looking for further information on this
    Original part number was 5K0 953 569 B . I bought a 5K0-953-569-AL from ebay. It came from a russian seller for about $275 AUD shipped to Adelaide.
    Also bought a Micro CAN cable from Ross tech to code the new module, which I will be selling soon.
    All good - steering wheel controls work again and I cleared the airbag fault and now the airbag light is clear too. Happy days.
